'76 Kz900-A4 Gauge Bulbs
- DoubleDub
18 Nov 2008 19:36
Kawasaki part diagram references part # 92069-018 for the gauge bulbs.
Does anyone know a place where I can cross reference this Kaw part # with aftermarket bulb part #'s (or know off the top of their heads which ones work)? The couple of stores I've browsed through don't have anything that matches the bulbs I removed.
Does anyone have an LED replacement part # and source that would be usable for this size 12v bulb socket?
Re: '76 Kz900-A4 Gauge Bulbs
18 Nov 2008 19:54
Sorry don't have cross-reference or info re LED's, but if unavailable locally (auto-supply store??), Z1E carries them.
gauge bulbs
Good Luck!
gauge bulbs
Good Luck!
- RonKZ650
18 Nov 2008 19:58
#53 bulb available anywhere works just fine. Yes it's not as bright, as we all know. It works fine to me.
- timebomb33
18 Nov 2008 20:02
are they the push in type or the screw in type if they are the screw in type then i can help you they are 194 bulbs as far as led's go im pretty sure that they aren't avaliable at this time.
I THINK MY POWERBAND BROKE
- MFolks
18 Nov 2008 20:18
I've found the 168 and 194 bulbs to be close in light output. Any good auto parts store should carry them.
If you want to switch to LED's www.radiantz.com (I think) has them.
- DoubleDub
18 Nov 2008 21:40
Thanks guys! They are the push and twist type.
For some reason I couldn't find them when browsing the bikes by model on Z1E - I have other items that I need to order from there anyhow, so I might go that way for now.
- Beatpoet
