tank swap?
- stilkikin
- Why the **** did I do that?
tank swap?
06 Sep 2008 16:00
I have a 78 kz650sr and I'm not a big fan of the style of the tank, plus it has no cap either. I was wondering if any of you experts here can tell me if I can swap a regular 650 tank on to it without to much hassle. I guess what I'm getting at is will it drop right in or not? Thanks for the help.
82 KZ750L
78 KZ650SR
78 KZ650SR
- The Gringo
- ¡Usted no necesita otra motocicleta!
Re: tank swap?
06 Sep 2008 19:21
The answer to your question is yes and no. The stock 650 tank will mount up just fine both front and rear, but the SR tank is shorter so if you put the Std 650 tank on your SR you will run into issues with the front of your seat being in the way. I hope this makes sense, the SR has a longer seat than the 650 B or C to fill the gap of the shorter tank.
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
KZ 550 times 2 80 440LTD-Sold
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
- stilkikin
Re: tank swap?
06 Sep 2008 19:27 - 07 Sep 2008 06:34
Sounds good so far. It's not a big concern about the seat cause I'm going to be doing a custom seatpan and rear cowl anyway. Is there any difference in the petcock or the mounting rubber? Thanks for the info.
82 KZ750L
78 KZ650SR
78 KZ650SR
Last edit: 07 Sep 2008 06:34 by stilkikin.
- The Gringo
Re: tank swap?
06 Sep 2008 20:55
No, the petcock and mounting rubber is the same. If you do the swap you will lose the low fuel warning light though. The 650 B&C tanks don't have a hole in the right side to accept the sensor.
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
- HansNOR
Re: tank swap?
07 Sep 2008 05:59
i just put an old round tank on my SR instead of the coffin tank - i need more fuel - and i think the old round one looks better. it's true that the tank rubs more on the seat - but i'm putting a kz seat on mine and redoing the back of the bike so it looks like a std KZ and not the saggy bottomed SR
only thing i miss is the fuel warning thingie - but i guess i'll drill a hole for it .
o 198x Kawasaki GPZ 750 (year will be updated)
x 1981 Kawasaki KZ 650 SR
- stilkikin
Re: tank swap?
07 Sep 2008 06:39
In respect to the low fuel warning light, isn't that what the reserve is for? The way I see it the less wiring the better. I'd like to remove as much wiring as possible and go bare bones, kickstart and just enough to make it street legal. Does anyone know where to get a plate to cover the hole for the starter by the way?
82 KZ750L
78 KZ650SR
78 KZ650SR
