Tank Exterior Cleaning
- Justyn
11 Aug 2008 13:41
My tank has some "gunk" buildup on the outside of it. I tried, quite quickly, to clean it with some aerosol multi-purpose cleaner and then a little bit of gasoline. Neither really made a difference.
I like the stock paint on the bike. It's a sparkley purple, with an organish iridescence. There is just some buildup robbing the luster and shine, probably because it's thirty years old. I was wondering if anyone had some tips as to what would clean the gunk, without harming the underlying finish. I'd like to clean the side covers too, but those aren't nearly as gunky.
For the record, I'm told that gunk is the technical term.
I appreciate any help you all can provide.
1980 750 LTD (kz750h) Wausau, WI
- Locozuna
Re: Tank Exterior Cleaning
11 Aug 2008 15:06 - 11 Aug 2008 15:09
Sounds like a job for Simple Green! But then again ....you used gas???????? :ohmy: :ohmy: :ohmy: :ohmy: :ohmy: :ohmy:
I'm not sure the term gunk IS correct. Ever see the movie "The Blob"??????
:blink:
Stock = Sparkely Purple????? not computing........ :S :S :S :S :S :pinch:
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
Last edit: 11 Aug 2008 15:09 by Locozuna.
- KOOL RYDER
- KZ 650B2 / KZ 1000E
11 Aug 2008 15:09
wd 40 try it on an incospicuas area first. worked for me.
Rockin\' a KZ650B2 since 2007 and a KZ 1000E since 2008
1978 KZ650B
1979 KZ1000ST
1978 KZ650B
1979 KZ1000ST
- ericvm
11 Aug 2008 19:03
what about carefully and gently polishing the clearcoat with a paint polish? Worked for me once.
\'82 Gpz 750 (KZ 750 R)
- Justyn
12 Aug 2008 16:09It was only a tiny splash of gas, and I've seen it clean other things quite well. I figured being I used it on the gas tank, Kawasaki had enough foresight to treat it against any negative effects gas may have. But I also seem to have momentarily forgotten about the saying about assuming....But then again ....you used gas????????
No, I've never seen The Blob.
Well I'm guessing that it's stock paint. The side covers and tank match very well. It doesn't look like a paint job someone would have done, but it is missing tank badges, so who knows. I know next to nothing about the history of this bike that my joker friends named purple rain.Stock = Sparkely Purple????? not computing........
It's a darker purple that seems to have very fine glitter mixed into it, much finer than the stuff strippers wear.
It looks like there are some dust and dirt particles in the gunk, so I'm a bit weary of using much friction.
I think I'll give some WD40 a shot, cause I've got lots of that around. If that doesn't work, then I guess I'll buy some simple green.
- Locozuna
12 Aug 2008 16:34
I seem to remember a purple 2 stroker that might have been a Kaw but I can't remember a 750 Purple Rain
. Thats not to say I'm not wrong....It's bound to happen someday!!!:woohoo: :woohoo: :woohoo:
I only said "GAS!" cause it is the great ruiner of paint jobs. Only thing more deadly seems to be brake fluid or magma!
"The Blob" was good! Steve McQueen was a wise guy hero but the goo was the real star. I especially remember someone playing with it on a stick letting it slide down a stick when it suddenly slid up and onto their hand. :blink: :blink: :blink: :blink:
:evil: :evil: :evil: :evil: :evil:
Would like to see pictures when you get a chance and good luck chasing away the goo!
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
- Old Man Rock
12 Aug 2008 17:20 - 12 Aug 2008 17:29
"The Blob"... Is that KOOL RYDER avatar image?
OMR
BTW, one thing that has been working in a lot of different cleanings has been Oops! Stuff works pretty well, not sure what it will do to the paint though.
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 12 Aug 2008 17:29 by Old Man Rock.
- KOOL RYDER
13 Aug 2008 12:53
Did the WD 40 solve your problem?
1978 KZ650B
1979 KZ1000ST
1978 KZ650B
1979 KZ1000ST
- Old Man Rock
16 Aug 2008 12:51 - 16 Aug 2008 12:52
Hell with the problem.... I must know, "avatar image".
That's some serious Booty!
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 16 Aug 2008 12:52 by Old Man Rock.
