I messed up screw threads for tank emblems
  • nob_1100
  • nob_1100's Avatar Topic Author
05 Aug 2008 02:08
#230248
Hi guys,
I'm currently repainting the gas tank and side covers of my 1100 Ltd Shaft, but in the process I stripped three out of the four tank emblem screws. I drilled out the screw heads to remove the emblems.
Now the painting work is nearly complete, I have to think of ways to put the emblems back on. I drilled a small hole in the center of the screw stem hoping to remove the leftover pieces of metal. It didn't work. What would be the best way to restore the threads? Do I need to tap threads? (Never done that before.) Or should I just "cheat" by using double-sided tapes or glues instead of the screws? Thanks!
Nob
83 1100 Ltd
  • jimmybon
  • jimmybon's Avatar
Re: I messed up screw threads for tank emblems
05 Aug 2008 03:44
#230251
cheat
74 Z1A900 original
74 Z1A900 stone replica
74Z1A900 barn find
77 Z650B1 Hybrid
81 z650 PIG camp bike
06 ZRX1200R cafe racer project
S1000xr
  • Old Man Rock
  • Old Man Rock's Avatar
05 Aug 2008 04:55
#230258
Go to Wally World (WalMart) and buy some E6000, stuff is amazing. It dries pliable but strong. If it needs to be removed it can. We use it at work, and seriously, this crap does work!
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • Locozuna
  • Locozuna's Avatar
05 Aug 2008 05:43
#230262
OMR has it right! That stuff is good or GE Silicone Adhesive Sealant Works great and lasts forever.
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
  • JMKZHI
  • JMKZHI's Avatar
Re: .
05 Aug 2008 07:26 - 04 Dec 2008 07:30
#230279
del
Last edit: 04 Dec 2008 07:30 by JMKZHI.
  • nob_1100
05 Aug 2008 07:36
#230282
Thanks guys! I'll give a try to E6000.
83 1100 Ltd
  • harm
  • harm's Avatar
  • Tom
05 Aug 2008 09:42
#230301
You may also try a left hand drill bit. With the drill in reverse it may spin the rest of the screw out! I have used this on several occasions and it usually works well.
Tom
Holland, MI
1980 KZ550 ELR
2011 Concours14
2017 KX450 [/color]
  • wiredgeorge
  • wiredgeorge's Avatar
05 Aug 2008 10:47
#230315
The screws that hold the tank badges are pan type and if you use anything except a pan screw, it looks kind of tacky. The screws are M3 w/ .5 pitch and if you strip these, you can't really do much because if you use M4 screws after retapping, the pan head won't fit in the countersink in the badge. Best to glue on the badges at this point.
  • BSKZ650
  • BSKZ650's Avatar
05 Aug 2008 14:38
#230348
permatex made a liquid thread repair product, I am not sure if they still make it, but you were able to fill the hole with the "glue" insert the screw and let it dry, after that you could back out the screw and have a fixed thread,
I havent seen it in a while, but the stuff worked great for no load bearing repairs
77 ltd1000, current rider
76 kz900, just waiting
  • KOOL RYDER
  • KOOL RYDER's Avatar
  • KZ 650B2 / KZ 1000E
13 Aug 2008 01:11
#231725
Here is another idea.....I used rivets.
It is not countersunk, but does look pretty cool and permenant, unless someone else wants to repaint the bike long after i am gone.
Rockin\' a KZ650B2 since 2007 and a KZ 1000E since 2008
1978 KZ650B
1979 KZ1000ST
