Gas Tank Swap 1980 KZ 750 H1 LTD
  • hammmy
  • hammmy's Avatar Topic Author
20 Jul 2008 10:30
#227262
Does anyone know what models' gas tanks are a direct swap for the 1980 KZ 750 H1 LTD? I'm not a big fan of the dinky little tank's capacity or looks.
1980 KZ750-4 LTD H1
  • Fenian
  • Fenian's Avatar
Re: Gas Tank Swap 1980 KZ 750 H1 LTD
18 Sep 2011 10:44
#477629
I am curious to see if you found out anything. I have the same question, an 81 KZ750 with that dinky gas tank...have you heard of any larger tanks out there that would swap over with minimal fuss? It seems that there are a lot of options for the CB750...not so much for the KZ. I was thinking that I may either pick up a second tank, then cut it vertically and horizontally and have more sheet metal welded in...
Always be wary of any helpful item that weighs less than its operating manual. (Terry Pratchett)
81 KZ750H
54 HD pan/shovel
  • martin_csr
  • martin_csr's Avatar
Re: -
19 Sep 2011 08:37 - 15 Feb 2013 11:33
#477828
Last edit: 15 Feb 2013 11:33 by martin_csr.
  • krzyryder
  • krzyryder's Avatar
05 Aug 2013 11:11
#599917
Resurrecting: I'm same with Finean. I got an 81 LTD and am looking for a different tank. Anyone have any suggestions.
