DupliColor Wheel Paint: For Frame
- Old Man Rock
20 Jul 2008 07:40
Hey all,
In making some fabrication & adjustments (tank, seat & tail back 1") for increased turn radius (kz900 w/ ZX636 front end) I found my frame paint was chipping rather easily.
I had used PJ1 Frame Paint... Not knocking the paint, for it just didn't stick to the primer for which I believe to be my fault in in-proper prep! Same time, has to go!
With this in mind, hmmm, then I remembered reading about the chipping resistance and they do have it in flat black. So I figured what the hell, give it a shot.
I had to cut and weld on the side kick stand for it was too long for the new setup. The bike just didn't lean far enough where a strong wind may blow it over...
Then I etched prime and painted with the Wheel paint. Let it sit a few days then give it the impact test. I'm actually surprised where it didn't chip. I even used a sharp edge of a screw driver.
Sure it penetrated to the primer but what paint or powder coat for that matter wouldn't do the same. It just didn't chip! :woohoo:
Here we go, now to strip the old and put on the new....
Just thought I'd share. If someone else has used this product please share your results.
Old Man Rock
Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- KZErider
Re: DupliColor Wheel Paint: For Frame
20 Jul 2008 18:11
I haven't used it, yet, but that's what I was considering. My thinking was that if it's made for wheels, it might have some built-in toughness. Let us know what your experience turns out to be. Thanks!
81 KZ750E2(project), 81 KZ750E2(parts donor), 87 BMW K 75C - got it runnin, didn't care for it, holding for family member, 79 CB650(project) Nomad 1700, VStar 950
- mtkawboy
22 Jul 2008 13:26
It sure holds up on bike & truck wheels. All Ive ever used is the Chevy rally wheel silver. I do my Honda Trail 70 wheels with it and some black mags for a 650 yamaha, plus my old 87 Toyota 4x4 wheels {Spanish Chrome}
- Old Man Rock
27 Jul 2008 11:17 - 27 Jul 2008 11:19
So far so good.... Kick stand still holding up to impact...Seems to be getting a little tougher with cure time.
I had completely wire wheeled the frame to bare metal, etch primer and painted the frame. Dries to a slight gloss over flat black (light sheen).
NOTE: Can states primer then 400 grit then paint. I tried this and didn't get the same results as primer, wait the 30 minutes then paint (also on the can)!
It didn't actually chip but it didn't adhere to the primer the same as the latter...
I'm going to let it sit for a couple of days to cure then start putting her back together. In installing the engine with the PJ1 product, a couple of bumps/scrapes and she chipped...
I'll post the results, good or bad as always. Not ashamed to admit my ignorance at times... I know, I know, powder coat but I've already dumped a substantial amount of $$$ into this project and I still need to get the head done, tires, speedometer, electronic ignition and headlight. Also I may have some more fabrication to do on the back end (buffed under side and tire hugger) mounting...
So every dime saved at this point is a must (wifey poo getting suspicious on the $$$ spent)...DOH!
Run old man Run...:laugh:
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 27 Jul 2008 11:19 by Old Man Rock.
- JMKZHI
Last edit: 04 Dec 2008 07:14 by JMKZHI.
