tank dent
Re: tank dent
25 Mar 2009 20:10
#275441
Tyler wrote: "The dowel will come off, re-apply the glue and repeat about 10 times or until your happy with it."
Just curious, when you're satisfied that the dent is gone how do you clean off the glue? Ed
  • arai59
  • arai59's Avatar
Re: tank dent
25 Mar 2009 20:23 - 26 Mar 2009 05:35
#275444
RonKZ650 wrote:
The tank looks good. Who cares there's a dent. You can either have a nice looking tank with dent, or a piece of crap repaint without. Dent is preferable.
Rons right.........screw the dent. It adds character !:laugh: Lets folks know.....you're nuttier than a squirrel turd.
Last edit: 26 Mar 2009 05:35 by arai59.
  • Tyler
  • Tyler's Avatar
Re: tank dent
25 Mar 2009 21:22
#275454
The high temperature hot glue will come off with the dowell and if any stays on the tank it will peel off without leaving a mark. I used a 1" piece of nylon rod but I would bet you could use wood. The trick is the rocking motion, if you pull straight out it dosen't work as well. You need steadly increasing pressure untill is pops off. If you pull realy hard right away the glue will let got and not move the metal. Add force little by little until you feel the metal yield and try to hold that force. You would be surprised how well that method works.
"74 Yamaha DT 400 Enduro
