900/1000 A tank on LTD
  • zombiescustoms
  • zombiescustoms's Avatar Topic Author
02 Jul 2008 04:49
#223451
Will a regular 900/1000 tank drop on a 79 1000 ltd frame, from my recollection the frames are the same right?, I like the look of the standard tanks better, and I think they are a little larger to boot. thanks in advance!
1979 KZ1000 drag/street fighter
1015cc stock internals for now, 39 flattys, GSXR frontend, ZX9 rear wheel with 6 over chromoly arm, just a budget beater!
  • Old Man Rock
  • Old Man Rock's Avatar
Re: 900/1000 A tank on LTD
02 Jul 2008 05:25
#223459
Some will physically fit but not without issues.
Example, I have a KZ1000-A2 tank on my KZ900-A4. How I found this out is in researching the petcocks via the link below.
When I got this bike the tank had severe damaged from the forks hitting it. Now the PO had also broken the turn stops so hard to say exactly what is what.
You may have to move your tank and seat back a little to get it all to fit with out your forks hitting the tank. This may be required so your seat so it closes and latches properly as well.
In following the link, you can obtain OEM part numbers for matching... Depending on models and years, some do, some don't...
www.babbittsonline.com/pages/parts/viewbybrand/parts.aspx
Good luck,
Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • roystaylor
  • roystaylor's Avatar
02 Jul 2008 17:53 - 02 Jul 2008 17:56
#223580
There are no issues. It will fit right on and will look much better than that LTD tank. Hopefully the picture of the LTD I put together for a friend will post so you can see for yourself.
Last edit: 02 Jul 2008 17:56 by roystaylor. Reason: won't take image
  • mtkawboy
  • mtkawboy's Avatar
02 Jul 2008 18:05
#223584
Ive got a 78 tank, plastic & seat on my 80 LTD, works fine.
  • zombiescustoms
02 Jul 2008 18:14
#223587
OK now off to find a tank!!
  • zombiescustoms
16 Jul 2008 05:39
#226455
got a clean tank of e-bay and it fits just fine, any one know what the difference in capacity there is between the standard and LTD tanks?
  • PLUMMEN
  • PLUMMEN's Avatar
16 Jul 2008 08:51
#226495
it seems like its about double when you run out of gas with that little ltd tank and have to push it 5 miles,dont ask me how i know this!:laugh: its probably close to a gallon differance ;)
  • zombiescustoms
16 Jul 2008 09:10
#226498
.9 gal to be exact!
Thanks again
