gas cap kz650
- brianpclarke
gas cap kz650
24 Jun 2008 12:46
I have a 79 kz650 C and cannot figure how the heck to get the gas cap off.....its not in the clymer manual and couldnt find it on here.... maybe i am a little slow...but any help would be appreciated.
Its the kind of cap with a hinge on the rear and a pin running through it...
-Brian
1977 KZ650C
1976 Kz900 LTD
1977 KZ650C
1976 Kz900 LTD
- BSKZ650
Re: gas cap kz650
24 Jun 2008 13:07
you drive the pin out, and the cap will come off
77 ltd1000, current rider
76 kz900, just waiting
- RonKZ650
Re: gas cap kz650
24 Jun 2008 16:23
Yea it's a roll pin just held in by friction, it will drive out either side, but you need to be patient and carefull because you'll bend the mount on the tank to crap long before the pin drives out if you start simply pounding it. You're best if you want the tank to not get damaged to remove the tank where you can support the bracket with a piece of wood or something as you tap out the pin.
- Qdude
- It is all good.
Re: gas cap kz650
26 Jun 2008 21:49
I found a nail that was just smaller than the aperture in the cap, and filed the point flat. It made a great tool to tap out the pin.
77 KZ 650 C1.
77 KZ 650 C1.
77 KZ 650 C1.
Re: gas cap kz650
27 Jun 2008 09:13
It helps to put a little Kroil or other penetrating oil on the pin (don't get it on the tank). Then use 10,000 LITTLE taps (NOT 1 big whack) using a drift pin or other suitable tool to drive it.
