Handlebar mods
- soundlessroar
Re: Handlebar mods
04 Nov 2013 22:34
Re those shorter clutch and brake cables with the Superbike bars - do you happen to recall which exact cables you chose that were the right length? Thanks.
Tim
soundlessroar@gmail.com
Tim
soundlessroar
1980 KZ440 Ltd
1980 KZ440 Ltd
Re: Handlebar mods
05 Nov 2013 06:53If he doesn't reply, what you can do is disconnect your cables at one end, then figure out the overage.soundlessroar wrote: Re those shorter clutch and brake cables with the Superbike bars - do you happen to recall which exact cables you chose that were the right length? Thanks.
Tim
You should remove & measure your cables to verify how long they are & what the slack is.
Z1Enterprises.com lists the cable lengths & slack. Whatever cable you get, make sure the slack is the same or slightly greater than what your bike currently has, otherwise the fit may be too tight (don't ask how I know, doh).
- Beaner242
Re: Handlebar mods
05 Nov 2013 07:37
What Martin said. Also Motion Pro can make any length you need, and they have a very informative website.
1982 KZ1000K LTD Chopper
