Welding tips
- benhurmx
Welding tips
30 May 2008 08:33
Hi everybody,
I need to weld two brackets to the side of the frame(kz900) to hold zrx1200 brake and shifter controls setup. Since i am new to welding ( i bought a flux-cored wire welding unit). Do i need to remove all electrical setup (harness, battery, etc....) to proceed with the welding ?
Any tips greatly appreciated! Thanks
- StreetfighterKz
Re: Welding tips
30 May 2008 09:48
I think the only thing you probably really need to do is diconnect and maybe remove the battery and make sure the leads aren't touching the frame anywhere.
Later, Doug
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- benhurmx
- Makarth
Re: Welding tips
30 May 2008 11:09 - 30 May 2008 11:10
practice on scrap metal for temp and feed rate, it's easy to burn through these frames. And the more time spent on preping the bike the better the weld (welding is all about patience)you want to make sure the area is clean so burning paint doesn't cause air bubbles in your welding bead. The other thing since you're using a flux core make sure to cover your engine with something to prevent the metal from splashing on too it (flux-core likes to make a mess). I have an old thread on how to weld with oxy-acetylene and they share the same principle.
edit: kzrider.com/index.php?option=com_kunena&...77957&catid=5#177957
Last edit: 30 May 2008 11:10 by Makarth.
- KZQ
- Administrator
Re: Welding tips
30 May 2008 17:31
For sure just tack your pieces then stop and check you alignment and positioning then using a wire brush reclean the area. Once you're satisfied with the locations weld it up. Weld right through your tacks as if they weren't there.
KZCSI
KZCSI
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Riders:
Projects:
1985 ZN1300
- benhurmx
Re: Welding tips
31 May 2008 05:19
Thanks for your advices, they will sure help. I am still waiting to get the welder by mail(bought it off ebay). I'll need to buy a good welding face shield too.....Will let you know how it went. Thanks
- Makarth
Re: Welding tips
31 May 2008 14:49
make sure to get a shade #9 at least. i use #10 when arc welding of any type.
