Painting flimsy plastic
  • Qdude
  • Qdude's Avatar Topic Author
  • It is all good.
29 Apr 2008 10:08
#210037
My buddy saw what I did to my bike, and now wants to paint his.
It is a dirt bike, and the front fender is not meant to be rigid.
I was wondering if he could expect the paint to reasonably adhere to the flimsy plastic parts. Sanding with 60 grit with a circular sander first?
I expect the paint would crack and peel once that fender starts bouncing around.
77 KZ 650 C1.
77 KZ 650 C1.
  • btchalice
  • btchalice's Avatar
Re: Painting flimsy plastic
29 Apr 2008 10:38
#210043
Terry Meyer / Wichita KS
76 kz900 w/1000 motor TWZTD
  • mariozappa
  • mariozappa's Avatar
29 Apr 2008 12:36
#210077
The krylon works good.
Also, you can buy 'adhesion promoter' to spray on before you primer and paint. It helps the paint not crack on flexable plastic.
1977 KZ650C1
and the KZ650/KZ750 Conversion ;)
  • ZER
  • ZER's Avatar
29 Apr 2008 15:30
#210106
Pactra makes a paint for lexan RC car bodies that bonds to most plastics. It comes in 2/3oz bottles for airbrushing, or the standard mini rattlecan.
Lexan RC bodies as you know are EXTREMELY flexible, and the Pactra paint never chips or peals
Check the local RC/Hobby shop, or online for it.
One thing to consider though, it comes out as a FLAT paint since it is supposed to be used sprayed to the inside of the body. But a standard rattlecan of clear enamel should then bond to the Pactra paint.
Michigan Yooper
1983 KZ440 LTD Belt Drive,(drag bars, smoothed side covers, shaved seat, pod filters, bar end mirrors) 1981 KZ440 LTD (parts bike)
  • tool maker
  • tool maker's Avatar
29 Apr 2008 18:00
#210147
You may get away with adding a flexant to your auto paint, But I'm not sure how much it will give without cracking.
Good luck.
Lancaster, PA
82 KZ1000 M2, stage 3 jet kit, pods, 4 into 1 Mac, Accel coils & wires.
  • Qdude
  • It is all good.
29 Apr 2008 19:49
#210178
Thanks all!!
77 KZ 650 C1.
77 KZ 650 C1.
