How to use buffing compound stick
- storysunfolding
01 Feb 2006 17:17
How do you get the compound out of the tube? I bought the ryobi brand and it looked like a cardboard tube with a wax about an inch inside the tube. How do I get that to stick out so I can apply it on the buffing wheel?
- steell
Re: How to use buffing compound stick
01 Feb 2006 17:38
Usually I buy it in 2 lb bars, but I have a couple of tubes (not Ryobi though) and the stick just falls out of the tube when I remove the cap.
Maybe you can pop off the other end of the tube and push it out?
- mykznme
01 Feb 2006 17:39
cut it.
Post edited by: mykznme, at: 2006/02/01 20:40
R.I.P. Odd Ivar
- Sandy
- Fly High,Tony
01 Feb 2006 19:33
Yes...cut and peel the cardboard outer,to expose the polishing stick inside.
1977 KZ1000 A-1
- racer54
01 Feb 2006 20:11
Where are you guys getting your supplies? I have found one place to get compound but what do you use to buff with...handheld wheel, electric buffer, what? Where are you getting your supplies?
- wireman
01 Feb 2006 20:25
a decent sized bench grinder with a buffing wheel on it works fine for smaller parts a fullsize diegrinder with some cones works good for larger parts like swingarms and frames.if you do a lot of polishing you can pickup large sticks of compound from plating shops!:whistle: goodluck,happy polishing!
- steell
02 Feb 2006 08:26
3000 rpm 3/8" drill, Dremel, 7" hand grinder, and a dual wheel 1 1/2 hp pedestal buffing machine (variable speed).
I get my supplies from Caswell, and here's a link to their "How to buff and polish" page.
Caswell
Post edited by: steell, at: 2006/02/02 11:29
Caswell
- roy-b-boy-b
02 Feb 2006 08:57
I got my supplies from Tarheel supplies. They have a Shaft, pulleys, and pillar bearings for around ten bucks. You can build your own stationary buffer. Mine works great. Roy
