Rubbing compound, hand or wheel?
- Qdude
- It is all good.
16 Apr 2008 08:37
Found out I got a little left arm tendonitis to deal with due to repetitive motion at work. Now I want to buff out the clear on my new paint with rubbing compound.
I realize that using power tools can burn through the paint easily, and perhaps it can leave scratch marks. But couple that with my desire to not use repetitive motion.
Should I absolutely not use a power tool to buff my paint job??
If it is possible to use a power tool, what are any recommendations??
77 KZ 650 C1.
77 KZ 650 C1.
77 KZ 650 C1.
- mariozappa
Re: Rubbing compound, hand or wheel?
16 Apr 2008 08:49
If your paint is from a spray can, I would do it by hand.
1977 KZ650C1
and the KZ650/KZ750 Conversion
- JMKZHI
Last edit: 04 Dec 2008 05:52 by JMKZHI.
- HerrDeacon
16 Apr 2008 12:51
I always use a power tool unless the area cannot be reached with it, then I do it by hand. I have a Porter Cable Dual Action polisher and it's variable speed. I have three foam pads with it that vary in agressiveness. With these three I use Meguiar's Dual Action Cleaner/Polisher (#83), then #9 like JMKZHI uses and then finish with #3 Machine Glaze. Usually get good results with this setup.
- Qdude
- It is all good.
16 Apr 2008 12:56
This is with the spray can paint, right?
As I understand it, the rattle can paint is much softer and apt to burn/melt.
77 KZ 650 C1.
77 KZ 650 C1.
77 KZ 650 C1.
- RonKZ650
16 Apr 2008 13:43
Qdude wrote:
They are all apt to that, but I'm sure rattlecan is even more so. You're going through an awful lot of trouble trying to make a nice job, I'll give you that.
- JMKZHI
Last edit: 04 Dec 2008 05:53 by JMKZHI.
- HerrDeacon
16 Apr 2008 15:23
WOW, that turned out awesome JMK, really good job. No better feeling than doing it yourself too, is it?
With regard to the melting or burning through the rattle paint with a machine, this is more apt to happen with a polisher that doesn't oscillate (i.e. like the pros use). The one I have is a dual action which is far safer to use for the average joe. Can still do damage but its much harder to.
- Qdude
- It is all good.
16 Apr 2008 16:07
Wonderful job !! I am right behind you. :side:
77 KZ 650 C1.
77 KZ 650 C1.
77 KZ 650 C1.
- mariozappa
16 Apr 2008 18:25With regard to the melting or burning through the rattle paint with a machine, this is more apt to happen with a polisher that doesn't oscillate
That's what I was thinking of. I'm no pro, just have big tools. :laugh:
1977 KZ650C1
