fiberglass on abs?
  • jjdwoodman
  • jjdwoodman's Avatar Topic Author
  • Live free, or die.
fiberglass on abs?
13 Apr 2008 20:59
#206268
Hey guys! This may be a dumb question, but I have been modifying a fairing for my 650. I had to cut a section out to clear my guages, and now I am trying to fabricate on a mounting lip for the windshield, which will be made from what's left of the windshield off my Voyager. All the pieces are made of black ABS and I got them to fit together pretty close then used woven fiberglass mat to tie them together.
After reading KZCSI's article "plastic repair" I wonder if the two part epoxy resin will stick to the ABS. I did scuff it very deep with 60 grit paper and cleaned it before beginning, but should I try to chip that off and go with the pipe glue?
I don't have a digital camera or I would post a pic of what I'm doing.
77 650b
81 550 Mostly there
83 ZN1300 Voyager
  • PLUMMEN
  • PLUMMEN's Avatar
Re: fiberglass on abs?
13 Apr 2008 21:04
#206269
id try the abs cement,but i dont like leaking water!oh wait ,its a fairing not plumbing.i know abs cement wont hurt abs plastic so id play it safeB)
  • agawam
  • agawam's Avatar
16 Apr 2008 21:09
#207053
an autobody supply store will have a repair kit for abs, also called a bumper repair kit
  • jimmybon
  • jimmybon's Avatar
16 Apr 2008 21:24
#207057
Welding abs is what i did, you need a hot air gun with a reducer and some abs strips. you would need to clamp your pieces together then heat for 5 seconds then using gloves push the abs repair strips onto the join then sand back. It takes a bit of getting used too, so practice on some scrap, cheersB)
74 Z1A900 original
74 Z1A900 stone replica
74Z1A900 barn find
77 Z650B1 Hybrid
81 z650 PIG camp bike
06 ZRX1200R cafe racer project
S1000xr
  • BSKZ650
  • BSKZ650's Avatar
17 Apr 2008 12:40
#207179
you can put the glass on but in time it will let loose,, ask how I know this,
I did some looking one time and found several sources for the repair products,, like always I dodnt save them, butthey are there
77 ltd1000, current rider
76 kz900, just waiting
  • jjdwoodman
17 Apr 2008 18:59
#207263
Sounds like the glass is not a good idea, so I guess my next question would be how to get it off without just waiting for a windshield to land in my lap?
77 650b
81 550 Mostly there
83 ZN1300 Voyager
