Vetter fairings
- Spot
Vetter fairings
12 Apr 2008 22:12
I have a Kawasaki Vetter fairing. Does anyone know where to get the lowers? How about mounting hardware? Some is still on the fairing, but nowhere near what the exploded diagram Craig Vetter has posted shows.:blink:
Good judgment comes from experience, which usually comes from bad judgment. - Will Rogers
- steell
Re: Vetter fairings
13 Apr 2008 06:36
Craig Vetter's site talks about lowers, as in which ones fit which models.
I have mounted two or three Windjammers on KZ's, and the only hardware was the one piece mounting frame. What hardware do you have?
- rdgrnr
Re: Vetter fairings
13 Apr 2008 06:47
Spot wrote:
What is your ride? I have a fairing bracket, and I think it's for a 1000. I can measure it up to my frame to see if it will work for you.
77 KZ650B1
80 440 LTD Sold
78 GL1000 Naked Wing Sold
80 CM400E Sold
Brainerd, MN
80 440 LTD Sold
80 CM400E Sold
Brainerd, MN
- Vter Bob
Re: Vetter fairings
13 Apr 2008 17:20
If you are looking for the mounting "hardware" for lowers on your Vetter fairing you can find them on ebay, or you can find them at
www.craigvetter.com
, or you can simply go to a hardware store and look for "well nuts" They are rubber pieces with a threaded metal piece embedded in the end. You press them into the holes in the fairing and the mounting screw passes through the lowers into the well nut. As you tighten the screw the well nut colapses locking the lower to the fairing. B)
Georgia, Vermont
1981 KZ550 LTD
1982 KZ1000 LTD
1999 ZG1000 Concours
Greetings from the Peoples Republic of Vermont, home of Ethan Allen, 2 American Presidents, a socialist US Senator and.....Homer & Bart Simpson
1981 KZ550 LTD
1982 KZ1000 LTD
- rdgrnr
Re: Vetter fairings
13 Apr 2008 18:00
The bracket I have bolts up to my 79 1000 frame...
77 KZ650B1
80 440 LTD Sold
80 CM400E Sold
Brainerd, MN
80 440 LTD Sold
80 CM400E Sold
Brainerd, MN
- mariozappa
Re: Vetter fairings
14 Apr 2008 07:08
I believe the lowers are TYPE 3 for the 650/900/1000 Kawasakis.
1977 KZ650C1
and the KZ650/KZ750 Conversion
- BSKZ650
Re: Vetter fairings
14 Apr 2008 13:04
I have a set of lowers that only fit one faring I have, the vetter faring used a plastic bolt if I remember, you can get just about anything at a hardware store to make them work
77 ltd1000, current rider
76 kz900, just waiting
- Vter Bob
Re: Vetter fairings
14 Apr 2008 15:12
They only used the plastic bolts to mount the windshield. A later update added a set of metal clips to the top outside mount points to cut down on cracking.
Georgia, Vermont
1981 KZ550 LTD
1982 KZ1000 LTD
1981 KZ550 LTD
1982 KZ1000 LTD
