KZ 650 Front Fender Options
  • seanof30306
  • seanof30306's Avatar Topic Author
03 Apr 2008 02:16 - 03 Apr 2008 02:17
#203906
'79 KZ650 B3
It has the old style front fender with the bracing strut. I want to go to something more modern looking. I saw this one, it's on an '83 ZN700. The forks look the same, would this bolt up? What else might work?
"That @#$%!!! KZ650"
79 KZ650 B3
Dual front disc brakes
Z1R 18" front wheel
Pumper carbs w/pods
MAC 4-1 w/ drilled-out baffle
Dyna S ignition w/ Dyna Green coils
WG coil mod
'81 CSR charging system
17/41 gearing
Last edit: 03 Apr 2008 02:17 by seanof30306.
  • 77_650B1
  • 77_650B1's Avatar
Re: KZ 650 Front Fender Options
03 Apr 2008 06:01 - 03 Apr 2008 06:03
#203925
Well you could always cut it off, i've seen that done. I've got this maier superbike fender on mine.
www.maier-mfg.com/shop.cfm?Product_ID=04...&modelid=&modelyear=
1977 KZ650-B1
-Dual Discs
-Dyna-S
-WG Coil Mod
-Alloy Wheels
Last edit: 03 Apr 2008 06:03 by 77_650B1.
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
03 Apr 2008 06:11 - 03 Apr 2008 06:14
#203927
I can't tell well enough from that little pic, but I believe that '83 has the axle in front of the forks, so the fender will be offset as well.
I've had an LTD 900/1000 front fender on, which is shorter than stock. Only thing is it allowed water to spray up under my gas tank and shorted out the electrics. :pinch:
Just needed to drill new mount holes to sit right:
I now hav an '83 (I believe) GPz750 front fender. It's wider, and needs to be squeeze to get in. New mount holes drilled again:
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
Last edit: 03 Apr 2008 06:14 by rstnick.
  • JMKZHI
  • JMKZHI's Avatar
Re: .
03 Apr 2008 09:07 - 04 Dec 2008 05:46
#203944
del
Last edit: 04 Dec 2008 05:46 by JMKZHI.
  • seanof30306
03 Apr 2008 12:33
#203993
I can't get the link toy work.
79 KZ650 B3
Z1R 18" front wheel
Pumper carbs w/pods
WG coil mod
17/41 gearing
  • 77_650B1
  • 77_650B1's Avatar
03 Apr 2008 12:35
#203994
works fine for me...
1977 KZ650-B1
-Dual Discs
-Dyna-S
-WG Coil Mod
-Alloy Wheels
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
04 Apr 2008 07:13
#204182
Link works here too.
Try this :
Maier
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
  • seanof30306
04 Apr 2008 13:00
#204242
Got it, thanks.
79 KZ650 B3
Z1R 18" front wheel
Pumper carbs w/pods
WG coil mod
17/41 gearing
