Side cover stays
  • Qdude
  • Qdude's Avatar Topic Author
  • It is all good.
Side cover stays
27 Mar 2008 16:54
#202562
What is the best way to get those rubber 'grommets' that are used to keep the side covers on?
Is there another method to keeping these things on?
77 KZ 650 C1.
77 KZ 650 C1.
  • quader98
  • quader98's Avatar
Re: Side cover stays
27 Mar 2008 17:12
#202564
im sorry dude,but do you want new grommets or a better way to keep the side covers on.if you need new grommets Z1 has got them.if your looking for a better way to keep them on uuuummmmm dunno,get new grommets,what i do is tie some fine string on it so if it does blow off it dosent go far
Ernie from central jersey
82 GPZ 750 R1
looking to part out my 81 KZ750E2
  • Qdude
  • It is all good.
27 Mar 2008 17:59
#202566
I needs to order me a box of these things, or at least 6.
Didn't know if they were available anymore, if not then I was looking for the alternative.
Cheers,
Q
77 KZ 650 C1.
77 KZ 650 C1.
  • KZQ
  • KZQ's Avatar
  • Away
  • Administrator
  • Administrator
27 Mar 2008 18:00
#202567
New grommets are the ticket. I've seen various clips and wires used but the real problem is that the old grommets just get hard and don't do a good job of grommeting. New grommets are readily available as quader98 has already posted.
KZCSI
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
  • 77_650B1
  • 77_650B1's Avatar
27 Mar 2008 18:32
#202576
z1enterprises.com old man
1977 KZ650-B1
-Dual Discs
-Dyna-S
-WG Coil Mod
-Alloy Wheels
  • Locozuna
  • Locozuna's Avatar
27 Mar 2008 19:38
#202589
Definitely get new grommets!
If you want some added insurance do this.
Make sure to leave enough so you can get off a side cover but not enough to have it hit the road. There is room behind the tabs to spread the cotter pin and not mark up your sidecover. Use a small dia cotterpin with long legs.
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
  • 79MKII
  • 79MKII's Avatar
  • Love Them Kaws!
28 Mar 2008 10:35
#202694
Once you get your grommet situation taken care of, here's another good way to keep those side covers on the bike:
The Kaw List:
  • JMKZHI
  • JMKZHI's Avatar
Re: .
28 Mar 2008 17:46 - 04 Dec 2008 05:47
#202782
del
Last edit: 04 Dec 2008 05:47 by JMKZHI.
  • Qdude
  • It is all good.
28 Mar 2008 23:41
#202844
Sweeeeeeet
77 KZ 650 C1.
77 KZ 650 C1.
  • 78z1Joe
  • 78z1Joe's Avatar
  • My man cave is my garage....
20 Apr 2008 08:13
#207807
Hi, your side cover problem could be fixed by wrapping electrical tape around the "nubs" of the side cover. it makes removal a little difficult, be careful and don't yank the side cover off and break it but the will stay on at speed. I did this to mine more than a few years ago and it has worked fine.
1978 KZ 1000
1982 GS 300 training bike
Previous Rides...
75 RD 350
72 CB 500 Four
72 SL 125
71 CT 70
69 3 1/2 HP mini bike
  • OKC_Kent
  • OKC_Kent's Avatar
20 Apr 2008 08:50
#207812
I found grommets at the local hardware store. They are thicker than OEM and the i.d. is a hair smaller; on my covers the posts are held tight, but also can not go all the way through the grommet hole. That might be a bad thing but I haven't had one shake or blow free yet.
Cashion, OK
78 KZ650 B2 85,000+ miles
  • patmann
  • patmann's Avatar
23 Apr 2008 08:57 - 23 Apr 2008 09:01
#208458
I figured after losing a side cover from my Z1, what I would do is... SPEND THE MONEY AND BUY THE RIGHT ONES FROM JEFF @ Z-1!!!
Sure a heck of a lot cheaper than, new/used cover ( $45.00 ), new/used 900 DOHC insigna ( $37.50 ), NEW paint to match the bike( $125.00 ).
I tried the cheap hardware store route too. It worked up until I went somewhat over the posted speedlimit :whistle:
But that's me;)
Pat
But I am running K&N's and don't have the airbox on either.
AND I have now used the old racer trick of drilling the small hole and cotterpin as shown above.
1974 900 Z1 modified to look like a LTD , some engine mods. But I still have all the original parts.
1977 1000 project bike
1972 H1 project bike
If pro is opposite of con, then what is the opposite of progress?
Last edit: 23 Apr 2008 09:01 by patmann.
