Pelicans on a 750B
  • flht1997
  • flht1997's Avatar Topic Author
Pelicans on a 750B
06 Mar 2008 16:10
#198781
Here was one of my winter projects. i was going to wait till it was 100% complete but i may have to shelve the other half for a bit so... this is what i did. i purchased three Pelican 1500's off ebay a couple months ago. if you do not know what a pelican is, they are a heavy duty plastic case, used mainly for photography and other electronic gear. they are water proof and darn near indestructable. they are pretty expensive new, mine were about 100 dollars each new. the ones i got came from a oil company in Texas, they were very dirty with a few holes drilled in them, but they were 10 dollars each. my mission was to build a rack that was spinley but strong. the bags need to come off fairly easily and they need to be solid enough not to wobble around. i am using the passenger peg, upper shock and the tail light bracket for mounting.
first picture is the upper shock mount i machined.
Matt Milwaukee, WI
75' KZ400, (5) 78' KZ400, 76' KZ 750, 78' KZ650
78'CB750F, 78' CB550K
89' BMW R100RT
05' H-D Electra Glide
06' KLR650
Do it right or don't bother doing it at all.
  • flht1997
Re: Pelicans on a 750B
06 Mar 2008 16:12
#198782
for the lower mount i bent a 1" by 1/8 flat stock to a 90 degree. i am using 1/2 inch square tube for the main frame. as seen here
Matt Milwaukee, WI
89' BMW R100RT
06' KLR650
  • flht1997
06 Mar 2008 16:14
#198783
side view in progress. i am a bit OCD about lines being close to straight. i have seen to many UJM's with ammo boxes mounted with threaded rods that i want this one right.
Matt Milwaukee, WI
89' BMW R100RT
06' KLR650
  • flht1997
06 Mar 2008 16:15
#198784
alright the upper frame is done, i just completed the bottom part. Mitered corners, doubled checked for straightness, gusseted and welded.
Matt Milwaukee, WI
89' BMW R100RT
06' KLR650
  • flht1997
06 Mar 2008 16:19
#198785
and here is the back side of the pelican with the upper mounts i machined to day. they will hook over at the top and be bolted at the bottom. the pelicans were safety orange when i got them and am still finishing them. they will be flat black when done.
Post edited by: flht1997, at: 2008/03/06 19:21
Matt Milwaukee, WI
89' BMW R100RT
06' KLR650
  • flht1997
06 Mar 2008 16:26
#198787
and this one is the bag sitting in place. there will be a rear support running from side to side, being bolted in the middle of the tail light mount. the rear turn signals will need to be relocated. i am not sure were they will go yet, i am thinking of a surface mount light, mounted to the rear support bar. but i am not sure yet.
Post edited by: flht1997, at: 2008/03/06 19:27
Post edited by: flht1997, at: 2008/03/06 22:13
Matt Milwaukee, WI
89' BMW R100RT
06' KLR650
  • ten6
  • ten6's Avatar
06 Mar 2008 16:32
#198788
Great work. It has inspired me to do something of the sort for my 650.
Michigan City, Indiana
Firefighter MCFD IAFF Local #475
(3) KZ650s (1) 1996 Vulcan 1500A (1) 1978 KZ1000 (1) 1986 Yamaha Radian 600
2000 Dodge Ram 4x4
1960 Chevy Bel-Air
  • Biquetoast
  • Biquetoast's Avatar
  • King Jeremy The Wicked
06 Mar 2008 19:11
#198824
flht1997 wrote:
and this one is the bag sitting in place....
That is so cool. I get way excited about utilitarian stuff. Looks like you nailed it man. Sleek, resourceful, and nothin' but business.
(1.) '75/'76 KZ400D - Commuter
(4.) '75 KZ400D - Sold
kz750twins.com
  • flht1997
11 Mar 2008 15:22
#199595
ok i made the mount for the other side, basically mirrored the left side for the right side. the gas ran out for the wire feed, so most of it is brazed together, so i will see how well it handles the vibrations. i guess it is somewhat rubber mounted cause the passenger pegs are rubber mounted on the B's
hope the picture comes through, first post on the new forum :)
Matt Milwaukee, WI
89' BMW R100RT
06' KLR650
  • HerrDeacon
  • HerrDeacon's Avatar
11 Mar 2008 16:26
#199607
Great work flht1997. I love DIY stuff like this. No better feeling knowing that you made it yourself. Great job!!
  • Biquetoast
11 Mar 2008 17:38
#199620
flht1997 wrote:
...the rear turn signals will need to be relocated. i am not sure were they will go yet, i am thinking of a surface mount light, mounted to the rear support bar. but i am not sure yet...
I got to thinking about this... You know, the U.K. 750 twins had the turn signals mounted right off the sides of the taillight (I assume due to their differing regulations). I wonder if you could get a hold of one of the U.K. brackets and see if your stock lights mount cleanly?
kz750twins.com
  • flht1997
12 Mar 2008 16:43
#199793
ok. made the rear support. not exactly like i wanted but it will be ok for now. and have been thinking about the rear blinkers also.
Matt Milwaukee, WI
89' BMW R100RT
06' KLR650
