Original grab bar
  • McGregor
  • McGregor's Avatar Topic Author
Original grab bar
26 Feb 2008 20:24
#197170
How do you do, gents.
Mayby somebody knows where I can buy an original grab bar for my baby?
Any advice will be greatly appreciated :)
Cheers
KZ1000M1 CSR 1981
  • McGregor
Re: Original grab bar
27 Feb 2008 15:39
#197257
Or aftermarket one...
Anyone:blink:
KZ1000M1 CSR 1981
  • 2M4Dale
  • 2M4Dale's Avatar
27 Feb 2008 15:56
#197260
I've seen 'em on Ebay ... Good Luck !!!
Hello from Sunny Mansfield, Ohio
1980 KZ750H1 LTD
1981 KZ750H2 LTD
  • dkmk
  • dkmk's Avatar
27 Feb 2008 16:03
#197262
You are looking for Kawasaki OEM part #32109-1027, which will fit both the '81 and '82 CSR, and the '81 and '82 LTD. Hope this helps... B)
Northern Ontario
Zapp: "Kif, I'm feeling the Captain's Itch."
Kif: "I'll get the powder, sir."
  • McGregor
27 Feb 2008 17:59
#197282
Thanks, dkmk:)
KZ1000M1 CSR 1981
  • Grantl
  • Grantl's Avatar
  • KZRider is Da Bomb!!!
27 Feb 2008 20:45
#197311
A member here aka Maverick offered to sell me one, but after I pm'd him offering to buy it I never heard back.
The CSR model grab bars don't come up often on ebay from what I've seen, so like McGregor says, watch for 81 and 82 LTD grab bars. A grab bar from any other model might look close but would require some modification to mount up and still might not look right.
Good hunting.
Grant.
1981 KZ1000 CSR
1983 KZ750 Project Bike
1990 550 Zephyr
1994 KZ1000 P
  • McGregor
27 Feb 2008 21:07
#197314
Another big thanks to dkmk for OEM part number :)
Z1 has it ( for now it's out of stock temporarily )
www.z1enterprises.com/detail.aspx?ID=29
So I'll wait :P
KZ1000M1 CSR 1981
27 Feb 2008 21:49
#197317
So I'll wait :P
Am thinking the mentioned Z1E grab rail is different as it fits the larger fours with tail pieces, and not the CSR/LTD models without tail pieces.
The Z1E listing shows a different part number (OEM: 35032-022) than the #32109-1027 provided by dkmk.
Would double-check the specific model application before ordering.
Just trying to save some trouble and possible disappointment.
Good luck with your quest (and hoping I'm wrong). :)
Post edited by: Patton, at: 2008/02/28 00:55
  • McGregor
28 Feb 2008 15:59
#197415
Thank you sir :)
When grab bar will be available, I'll give them a call and double-check.
Will keep you posted ;)
Cheers
KZ1000M1 CSR 1981
  • ltdrider
  • ltdrider's Avatar
28 Feb 2008 16:18
#197420
McGregor:
I can't tell if it's clear in this thread, but there are two different grab bars... one style for the LTD (stepped) seat, and one for the flat Standard seat. If your CSR still has the stepped seat, and you want it close to orignal, then you should try for the LTD grab bar. It's taller so that it sits above the taller seat back on the stepped seat.
Either bar will fit, but the Standard bard will sit lower behind the LTD seat.
'76 KZ900 LTD (Blaze)
'96 Voyager XII (Dark Star)
Greensboro, NC
  • McGregor
05 Mar 2008 20:43
#198635
Thanks itdrider, good info,
A still have stepped seat, so I'll try my best to find LTD g.bar...
KZ1000M1 CSR 1981
