Sidecover repair
  • Afrosemite
  • Afrosemite's Avatar Topic Author
Sidecover repair
24 Feb 2008 19:08
#196833
This must be a fairly common problem so hopefully people will know what I should do. Both my side covers are cracking near one of the rubber pieces that holds them to the bike. I was thinking about just putting some JB Weld on the back to hold it together but I thought it would be nice to get something stiff to glue on to give it more strength. Any suggestions on what I could use for a backing?
\'78 Kz650d sr
  • JMKZHI
  • JMKZHI's Avatar
Re: .
24 Feb 2008 19:32 - 03 Dec 2008 20:51
#196835
del
Last edit: 03 Dec 2008 20:51 by JMKZHI.
  • baldtire
  • baldtire's Avatar
Re: Sidecover repair
24 Feb 2008 19:41
#196837
gorilla glue and fiberglass cloth, use the glue like fiberglass resin
if you never used gorilla glue before try it on something first, it foams up as it sets, and it sags before it foams
two layers of cloth is almost a overkill
24 Feb 2008 20:03
#196841
Here's an excellent thread. :cheer:
Click Here!
Good luck with the repair! :)
  • PLUMMEN
  • PLUMMEN's Avatar
24 Feb 2008 20:58
#196854
v out the crack on the inside with a dremel to give the glue a little penetration like a weld.ive used a hot glue gun to fill the emblem holes on sidecovers before;)
  • 76 LTD
  • 76 LTD's Avatar
27 Feb 2008 06:41
#197199
Been there done that. 2 part epoxy.clean the area v out the crack fill with epoxy let setup and its better than new.if you want you can sand the area when done and clean it up a little.this is the way i have repaired several covers that were cracking around the studs.
  • OKC_Kent
  • OKC_Kent's Avatar
27 Feb 2008 13:31
#197244
Click Here!
In the post from the link above, KZCSI uses alcohol to clean up the plastic, then heads right for the ABS cement. I thought the ABS pipe cement requires a special primer, yes/no? Doesn't matter?
Cashion, OK
78 KZ650 B2 85,000+ miles
