turn signal options
- PMcD
turn signal options
29 Jan 2008 13:55
I have been thinking of some ways to change my turnsignals on my 650.
Has anybody tried using flush mount signals in the rear, I was thinking about putting them on the metal brace where the stock signals are.
Here is the link, tell me what you think of the idea.
www.exoticsportbike.com/flush_mount.htm
Any opinions are welcome. Thanks
- Bad Kaw
- Flying Squirell
Re: turn signal options
29 Jan 2008 15:58
1.) It's your bike, so if it's what you want, give it a go.
2.) At that price, I'd go to a local dealer and give him your business.
A. Because if you have a problem, you have a building to go to, and not a 'no return policy' on-line (invisible) store.
B. You might start a relationship with your local guy and it might pay-off down the road if you decide on more than turn indicators.
Take some pics and put 'em up; see what results you get.
-KR
-KR
78 Kawasaki Z1R
81 Kawasaki KZ1000J (mods)
70 Kawasaki KV75
83 Honda CB1100F (few mods)
70 Kawasaki KV75
- PMcD
29 Jan 2008 18:09
i'll think i'll find a good quality pair and buy em, I'll get pics if I do.
- quader98
04 Feb 2008 14:12
personally i don't like those,ive seen then on a gpz and just didnt look good
i prefer ones similar to these,not those exactly but similar.i have a set on mine and i like the way they look
tinyurl.com/365qle
tinyurl.com/365qle
Ernie from central jersey
82 GPZ 750 R1
looking to part out my 81 KZ750E2
82 GPZ 750 R1
- PMcD
09 Feb 2008 17:25
Thanks for your opinion, It helps when you see them on the bike. I believe that i may just put on an integrated taillight since i am thinking about removing the rear fender.
- quader98
09 Feb 2008 18:33
i'll take a pic tomorrow and you can see what they look like
82 GPZ 750 R1
82 GPZ 750 R1
- rstnick
10 Feb 2008 15:05
I was going to go with the integrated turn signal/tail light on my ZX6E tail light conversion, but I've changed my mind.
With the integrator, when the brake light is on, the signal wont flash.
I'll be going with some smaller than stock turn signals.
The ZX6E tail light:
Like the monoshock set up? :laugh:
Post edited by: rstnick, at: 2008/02/18 18:58
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- Biquetoast
- King Jeremy The Wicked
10 Feb 2008 16:10
rstnick wrote:
I have a Reese integrator on my 400, and the turn signals flash when the brake it on.I was going to go with the integrated turn signal/tail light on my ZX6E tail light conversion, but I've changed my mind.
With the integrator, when the brake light is on, the signal wont flash....
(1.) '75/'76 KZ400D - Sold
(4.) '75 KZ400D - Sold
kz750twins.com
kz750twins.com
- rstnick
10 Feb 2008 18:13the turn signals flash when the brake it on.
Really?
Reading through the thread about integrators, it was mentioned that the turn signal stops flashing when the brake is on.
Did you wire up the Reese integrator on your 400 like the wiring diagram in that post?
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- rstnick
10 Feb 2008 18:16
I see you mentioned "No, with it, I have four rear-facing lights. The outer two are running/turn/brake (on the trailer kit), and the inner two are wired to the stock running/brake. I love the way it works..."
You have 4 lights? Got a pic of that?
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- Biquetoast
10 Feb 2008 18:36
rstnick wrote:
In the pic below, the two center lights are the ones wired to the stock tail/brake, so ignore them for the purpose of this discussion. (By the way, I only run the two center lights to stock wiring because I didn't 100% trust the Reese kit.)
The outer two lights are wires to the Reese kit, so that would make them behave exactly like a standard dual-bulb under-tail light set. In fact, they end up behaving exactly like you would want trailer lights to behave with a dual-filament setup. With them, when I hit the brake, they both light up. When the running lights are on, they are running lights. When I turn on the turn signal, they blink. The turn signal will over-ride the brake light if both are in effect, so if one side is blinking, the other side is either a running light or a brake light.
I hope that makes sense...
On a side note, I the reason I did this is because even though most of you guys like to have *fewer* lights on your bikes, I actually wanted *more* braking visibility, with reasonable turn indicators, without having as many lights as a Gold Wing. This was my way of handling that compromise. And I don't care as much about the look as I suppose I should...
Post edited by: Biquetoast, at: 2008/02/10 21:44
kz750twins.com
kz750twins.com
- rstnick
11 Feb 2008 06:39
Part of the reason I switched my mind on using an integrator and going with turn signals is the visability angle. I want people behind me to see the signal clearly.
Years ago all 4 of my signals were running lights as well, to be seen well.
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
