650 fender eliminator template help
- PMcD
28 Jan 2008 18:28
I need a winter project, and am considering taking off my rear fender on my 1978 kz650 B. Does anyone have a template/dimensions that they could share, I'd really appreciate it.
I did do a search, and was wondering if 900 eliminators are the same?
Thanks.
Thanks.
- rstnick
Re: 650 fender eliminator template help
28 Jan 2008 18:54
Mounting holes would be a little different with a 900 template.
I'm using a spare rear inner plastic fender, cut short and turned around to the back, continuing off from where the front inner fender finishes off.
You can use this inner fender as a mounting template for a piece of metal you may want to use.
Here's how my light was mounted, although I changing over to a ZX6E tail light this Winter:
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- PMcD
29 Jan 2008 14:28
Thanks I began making a bracket similar to that, I'll see where I can take it, as soon as the weather cooperates. Negative degrees = not fun.
- mariozappa
04 Feb 2008 13:16
nevermind!
:whistle:
Post edited by: mariozappa, at: 2008/02/04 16:17
:whistle:
1977 KZ650C1
and the KZ650/KZ750 Conversion
