painting chrome
- boomboom45
painting chrome
27 Oct 2007 07:19
i am sure someone has asked this before but, what is the best way to paint over chrome? the exhaust has chips all through it, and im thinking of blacking out the whole bike.
- harm
- Tom
Re: painting chrome
27 Oct 2007 07:28
When i painted over my chrome fender i sandblasted it first. It worked great!
It would be tough to sandblast the pipes though unless you have access to a fairly large sandblaster.
One of those hand held blasters would work but it would take a while
Tom
Holland, MI
1980 KZ550 ELR
2011 Concours14
2017 KX450 [/color]
Holland, MI
1980 KZ550 ELR
2011 Concours14
2017 KX450 [/color]
- Bluemeanie
Re: painting chrome
27 Oct 2007 07:51
I "blacked" out my bike (the chrome) over 20 years ago with rattle can semi gloss black. It worked great but now your talking about exhaust heat, etc. Sand blasting would be great or at least a really good sanding? Most members here use really high temp barbeque paint! Let us know.
- otakar
Re: painting chrome
27 Oct 2007 07:53
I painted my Chrome fender black also. The easest way is to soke it in a 25% solution of Muriatic acid which can be bought at your local hardware store. This will remove the Chrome, the rust, but not the Nickle. This is actually beneficial. I let it soke overnight. Than I lightly brushed it with a Scotchbright pad to remove anything els which may have loosened up and than wrinced it off with destiled water to prevent further rusting. The best paint to use is Por-15. When it dryes it is permenant. This takes about three days. But you can handle the part in about 12 hours Por-15 makes a good header paint also.
www.por15.com/?gclid=CKak7POrr48CFR8ZIwodnwyNMA
Post edited by: otakar, at: 2007/10/27 10:55
Post edited by: otakar, at: 2007/10/27 11:00
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Re: painting chrome
27 Oct 2007 07:55
I brushed muratic acid all over the header pipes to "prime" them before painting. Do this outside in a well-ventilated area using rubber gloves and eye protection, and don't breathe the fumes as muratic acid on chrome reportedly re-acts to form some poisonous gas (cyanide?). Rinse well with water by hosing down. Then won't hurt to do a little fine wet-sanding. Dry thoroughly. Spray paint with several light coats of Flame-Proof Hi-Temp from auto-parts store). I used "flat black" which has lasted very well for over two years and still appears freshly painted with no flaking or peeling.
P.S. The muratic acid was applied continuously and allowed to remain on the header pipes for only a minute or so. It works quickly.
Post edited by: Patton, at: 2007/10/27 11:00
- boomboom45
Re: painting chrome
29 Oct 2007 20:21
thanks for the excellant ideas guys. ill let you know how it turns out. one of these days i need to post the pics of her, as soon as i figure out how to decrease the pic size
- PMcD
Re: painting chrome
04 Nov 2007 14:20
I have never tried it but i have heard of guys sanding the chrome, if you have the time, and then using an etching primer, followed but a "regular" primer, and then painting. But im not sure if it could take the heat.
- Oldhemi
Re: painting chrome
05 Nov 2007 16:39
IF you have a nearby chrome shop, you can ask them to strip it for you. They won't charge much, if they are cooperative. They have to do it anyway when they have to do a re-chrome. Fast, easy, cheap and no metal eating sandblasting. Note, most shops do not like mucking with used exhausts due to all the crap inside of them.
- boomboom45
Re: painting chrome
12 Nov 2007 18:21
well its done, all blacked out. took some high temp grill paint, and it looks awesome. the paint looks like the finish on my sig. like a flat black all around, with a bright blue strip in the middle of the tank. anyone know how to convert it so i can post the pics?
