idiot question....
- squints
idiot question....
18 Oct 2007 16:01
how do you disassemble a turnsignal from the stem. I want to shorten the stock stems in the back, but I cant even get them apart from the actual signal. I looked at the parts diagrams, do i just pull till they come off???
traded my classic Kz's for a 2001 Kz1200r
Upstate NY
Upstate NY
- The Milkman
Re: idiot question....
18 Oct 2007 16:03
You have to take the bolt all of the way out, it fits into a groove in the shaft. I also helps to put a thick screwdriver or a chisel or some other wedge into the slot to help loosen it from the shaft.
Ride safe
Ride safe
- squints
18 Oct 2007 17:03
huh? bolt? the one that tightens the signal on like a clamp? yeah i removed that one and its still not coming off, how much do i have to pry open that slot??
thanks dude
thanks dude
Upstate NY
Upstate NY
- The Milkman
18 Oct 2007 17:26
just enough to crack the rust, it comes off fairly hard.
Ride safe
Ride safe
18 Oct 2007 18:07
You may also want to put a little Kroil on it and let it work overnight. Ed
