Turnsignal Fork Relocation For Fairing?
  • Strizzzo
  • Strizzzo's Avatar Topic Author
  • 78 Kz1000A
13 Sep 2007 07:43
#170338
Howdy all - looking to add a standard cafe fairing to my 78 Kz1000. Seems like relocating the turn signals to the forks may be ultimately easier than cutting out the fairing to accommodate them as they exist on the headlight bracket.
Anyone know of good clamps for putting the signals on the frame? I'm not terribly good with cutting plastics (already ruined one of these fairings :blink: )
Also open to any other suggestion on to how to easily add the faring without loosing the turn signals?
Thanks.
78 Kz1075A2
Portland, ME
  • duncan
  • duncan's Avatar
Re: Turnsignal Fork Relocation For Fairing?
13 Sep 2007 09:13
#170349
i used these clamps
from here:
www.accessoryinternational.com/turnsignals.html
i had to replace the turn signal stem as well. dennis kirk has 3 lengths. i used the medium length ones:
tinyurl.com/yw6xrs
i installed them using some garden hose black rubber washers to provide some shock absorption.
if you ever want to relocate the rear turn signals to accomodate luggage/saddlebags, this bracket works great:
tinyurl.com/jdvpg
i used the long turn signal stems at the back.
Post edited by: duncan, at: 2007/09/13 12:34
  • JMKZHI
  • JMKZHI's Avatar
Re: .
13 Sep 2007 12:27 - 03 Dec 2008 09:38
#170374
del
Last edit: 03 Dec 2008 09:38 by JMKZHI.
  • Strizzzo
  • 78 Kz1000A
19 Sep 2007 13:32
#171599
Many thanks for the advice. I'm ordering those brackets and will update w/ progress/regress once I have them.
78 Kz1075A2
Portland, ME
  • 2M4Dale
  • 2M4Dale's Avatar
26 Sep 2007 02:45
#172901
I relocated the front turns on my 80 kz750 LTD. I didn't like 'em on the bars ... soooooo ... I fabricated some L-brackets and moved the things to the lower triple clamp bolts. Brackets were made from 1/8 steel strip and drilled and test fitted .... then I made the little top covers and welded them on ... then I smoothed everything out and my final result came out looking "factory" I think !!! As you can see I also went with much smaller aftermaket lights.
Hello from Sunny Mansfield, Ohio
1980 KZ750H1 LTD
1981 KZ750H2 LTD
  • Strizzzo
  • 78 Kz1000A
02 Oct 2007 08:16
#174143
2M4Dale - DZAAAMN! That's what I'm talking about - hope you don't mind if I bite your approach. Will likely be a couple weeks till I can git'er done, but I'll post pics when I do.
-strizz
78 Kz1075A2
Portland, ME
  • Strizzzo
  • 78 Kz1000A
02 Oct 2007 08:18
#174144
-strizz
78 Kz1075A2
Portland, ME
  • 2M4Dale
  • 2M4Dale's Avatar
02 Oct 2007 15:19
#174213
Go for it Strizzzo ... I was hoping someone would like 'em !!! Looking forward to seeing your final results !
1980 KZ750H1 LTD
1981 KZ750H2 LTD
