Inspection
  • Bugg
  • Bugg's Avatar Topic Author
Inspection
09 Jan 2006 05:24
#16853
Can anyone tell me what they look at specifically in NY for an inspection, like do the they measure how far apart the turn signals are?? I'm looking to replace the stock stalks among other things
  • madderkaw
  • madderkaw's Avatar
Re: Inspection
09 Jan 2006 05:36
#16856
I've never seen anyone check the distance between turn signals. They will check to make sure that they work though. They also check your horn, high & low beams, brake light, and tail light. They may check your steering head for looseness, tire tread depth, brake pad thickness as well. I've never failed a New York State Inspection, and I've had some pretty dicey rides at times.
  • Bugg
Re: Inspection
09 Jan 2006 05:51
#16858
thanks, I was building a bumstop seat and I'm probably gonna make up a taillight,signal,plate unit and hang it underneath
  • KitNYC
  • KitNYC's Avatar
Re: Inspection
09 Jan 2006 16:50
#16942
You wouldn't happen to have a decent original seat, would you?
As for the inspection, they've never measured how far apart my signals are. I'm pretty sure the Buell signals I put on the Triumph are closer together than the stockers.
HTH,
-Kit
  • twist
  • twist's Avatar
Re: Inspection
09 Jan 2006 17:23
#16953
I've never had any problems in either NY, CT, or
other parts of New England with turn sig locations.
As you can see from this pic,... stalks? what stalks?
~twist
