Side covers - keep falling off 1978 KZ650B
  • jdornski
  • jdornski's Avatar Topic Author
  • 1978 KZ650B2, 1972 H2, 1974 CB500(oops)
03 Sep 2007 14:34
#168277
Hi:
I am very bitter. Finaly took amy firstlong ride on my recently restored 1978 KZ650B. The left side cover fell off(fortunately found it on the return trip)and later on the right one almost did the same.
Is there a quick fix?
Or can someone tell me where I can get the rubber grommets that hold them in place.
The good news side of this is I can now justify a repaint back to 1978 colours.
thanks
JD
1978 KZ650B2, 1972 H2, 1974 CB500, 1972 XJ650, 1984 Honda Aero 80, 1933 AJS 350 Big Port(part-owner)
,johndorn@shaw.ca
250-404-0318
  • PLUMMEN
  • PLUMMEN's Avatar
Re: Side covers - keep falling off 1978 KZ650B
03 Sep 2007 14:38
#168279
Z1 ENTERPRISES;) i always like to drill a little hole in top front corner and use a piece of chain like on a set of finger nail clippers looped around frame tube to hold it from flying off at high speeds,yes they will fly off even with new grommets.;)
03 Sep 2007 16:10
#168291
Thanks to an earlier post by 79MKII
  • flht1997
  • flht1997's Avatar
03 Sep 2007 16:13
#168292
i drill a small hole in the bottom lip on both sides and then attach a very small bungee cord holding both together. since i did that i have stopped reaching down every few miles to make sure they were still on
Matt Milwaukee, WI
75' KZ400, (5) 78' KZ400, 76' KZ 750, 78' KZ650
78'CB750F, 78' CB550K
89' BMW R100RT
05' H-D Electra Glide
06' KLR650
Do it right or don't bother doing it at all.
  • The Milkman
  • The Milkman's Avatar
03 Sep 2007 16:29
#168296
You can get new grommets as almost any hardware store. Not sure of the size but look for a store that has the midwest section, most hardwares do. You can find them there.
  • Jessz1
  • Jessz1's Avatar
03 Sep 2007 18:15
#168310
I never had them fall off with new grommets. A lot of guys pin them like the photo above shows. schnitz racing has the grommets in stock.
  • PLUMMEN
  • PLUMMEN's Avatar
03 Sep 2007 18:31
#168315
get ripping along at 100 plus with a set of k&ns on there and you will be shocked how much wind gets blowing up behind those side covers :P
  • Jessz1
  • Jessz1's Avatar
03 Sep 2007 19:00
#168326
Wierd, I have a 140 MPH dragbike and they don't fall off.... Must have an extra tight fitting set.:P
However, my strretbike they do fall off on but I haven't replaced the origional grommets yet. We will see what happens...
  • JMKZHI
  • JMKZHI's Avatar
Re: .
04 Sep 2007 05:19 - 03 Dec 2008 09:42
#168389
del
Last edit: 03 Dec 2008 09:42 by JMKZHI.
04 Sep 2007 05:41
#168393
Z1E carries side cover grommets.
Go to site and search "grommet" :)
  • Bluemeanie
  • Bluemeanie's Avatar
04 Sep 2007 16:49
#168544
Had mine for 27 years with factory grommets and have no problems, still snap in tight!
  • jdornski
04 Sep 2007 18:44
#168573
Kawasaki must have improved them the grommets between 1978 and 1980
,johndorn@shaw.ca
250-404-0318
