Removing gasoline \"etch\" from out side of tank
  • ZN700LTD
  • ZN700LTD's Avatar Topic Author
06 Jan 2006 21:58
#16472
I'm sure this has been covered but I don't seem to be having any luck when I do a search.
The gas tank on my '85 has quite a bit of discoloration and streaking from spilled gasoline. I'm looking for suggestions on good ways to remove this- at some point I'll probably have it professionally refinished, but right now, I 'm just trying to get it running and want to keep the tank from getting worse.
Thanks,
ZN700Ltd
  • mykznme
  • mykznme's Avatar
Re: Removing gasoline \"etch\" from out side of tank
07 Jan 2006 07:26
#16499
you could wet sand it and spray it with a couple of coats of urethane clear. it wont remove the discoloration but it will protect what you still have left.
mine is pretty bad too and as soon as i get the leaks out and get my new petcock im going to rattle-can it untill i get all my "pro" paint to do the whole bike.
R.I.P. Odd Ivar
  • gabriel
  • gabriel's Avatar
10 Jan 2006 17:08
#17146
I had the same thing though my tank has chiped paint as well and it needs some serious paint job. I did manage to remove the gas trails but it's very easy to damage the paint. Wet sand it with 1500 grit and then use rubbing compound (I used 3M rubbing compound) to get it all shiny again.
Gabriel
84 ZN700
  • RomSpaceKnight
  • RomSpaceKnight's Avatar
12 Jan 2006 15:28
#17541
Some waxes are very high in Carbondum (?). These types are more abrasive. Waxes actually get paint shiny by abrading a small top layer off as well as filing in imperfections. So you might try polishing the living hell out of it.
