Yet another tank question
- BUG
25 Jul 2007 19:39
well here goes i have recently started restoring my 81 750 LTD, it sat out in the weather for over 10 years.SO after cleaning the inside of the gas tank.and all rust has been removed i have noticed 3 tiny pin holes on the bottom side of the tank near the seam.my question is what is the best way to repair this? Any and all suggestion will be appreciated
- almarconi
Re: Yet another tank question
25 Jul 2007 20:13
There are several commercially available products you can use to seal your tank. Caswell plating has an epoxy for this purpose. Also available kreem,por-15,hirsch automotive and kbs offer products. You could also have the tank professionally repaired at most radiator shops.
Depends on how much you want to do yourself and how much money you want to spend. Here are some of the links
www.caswellplating.com/aids/epoxygas.htm
www.hirschauto.com/acb/showdetl.cfm?&DID...Product_ID=6&CATID=3
www.kbs-coatings.com/Tank-Sealer-C29.aspx
www.rags2riches-por15.com/faq_gastank.html
Use the search function on this forum or google, there are tons of articles on tank sealing. Good luck with your project.
1981 KZ550C LTD (SOLD)
1980 GS750L
1982 KZ750N1 Spectre (New Project)
1980 GS750L
