Side Cover Repair?
- KevZ
Side Cover Repair?
03 Jan 2006 15:31
My right side cover is missing a post. What are some options to fixing this? Of course, if anyone has one laying around they don't want, let me know.
- rstnick
Re: Side Cover Repair?
03 Jan 2006 19:10
One of my covers lowest post is missing. I drilled a small hole in the side cover near the edge, and used a Black Zip tie to fasten to the frame.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- wiredgeorge
04 Jan 2006 06:30
You can epoxy a bolt into the location where the post used to be. Use SLOW CURE (24 hour) epoxy. Most hardware stores sell a product called Mortite. This stuff is clay in a string form... you basically build a dam around the bolt (or whatever you can use to sub for the post) and then pour epoxy into the dam. The epoxy will not stick to the Mortite and once the epoxy is set, you just remove the Mortite and the epoxy will cover the bolt head and adhere well to the inner side of the cover. The epoxy is stronger than the original plastic. Drill a hole in the bolt and safety wire it or use a cotter pin to ensure it doesn't come out.
- KevZ
04 Jan 2006 09:55
Thank you for the suggestions, guys! Both ideas have their own merits, rstnick's idea provides a way to keep the cover attached to the bike on a semi-permanent basis, and WG's idea provides stealth. I jsut have to figure out which I prefer. Thanks, again.
- duncan
04 Jan 2006 12:52
another option involves drilling a hole in the sidecover, and using this hardware:
www.redlinecycle.com/Sidecovers%20Aftermarket.html
Post edited by: duncan, at: 2006/01/04 15:53
