Painting Engine
  • Night_Train01
  • Night_Train01's Avatar Topic Author
Painting Engine
16 Jul 2007 18:18
#157284
I just finished painting the engine on my Z1R project. I read somewhere on this site that Dupli-Color heat paint was a nere match for the original paint......I taped off the parts I didn't want painted and then applied three coats of the high heat paint....it was an exact match to the original, the engine looks brand new again:ohmy:
The advantage I had is the engine is out of the frame but for anyone looking to bring their engine back to shiny and new then this paint is your answer......
  • brich
  • brich's Avatar
Re: Painting Engine
16 Jul 2007 19:02
#157299
I agree man brother ... i used that a few times myself with great results. I even shot some high temp clear over the black to give it some shiney!!
1975 Z1 900, 1075 wiesco kit, web cams, smooth bores, dyna ignition, denco pipe, lester mags, wicked bad rotors, custom gauge face plates .. not much stock left.
  • Night_Train01
Re: Painting Engine
23 Jul 2007 18:05
#159021
I am just putting in a new valve cover gasket and then the engine will be going back into the frame
  • Little B
  • Little B's Avatar
Re: Painting Engine
24 Jul 2007 04:13
#159129
Looks good Night Train!
I read somewhere that painting an air cooled engine causes it to not be able to cool properly. Is that not true?
1981 KZ750-H2 LTD
  • donthekawguy
  • donthekawguy's Avatar
Re: Painting Engine
24 Jul 2007 06:12
#159148
It does hold a little hea in but they painted them at the factory so it's all good.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
  • Muddy
  • Muddy's Avatar
Re: Painting Engine
24 Jul 2007 06:40
#159157
What kind of prep work did you due to it before painting? I think I'm going to have to paint my engine as the previous owner spray painted his windjammer on the bike and got overspray everywhere.
  • Snakebyte
  • Snakebyte's Avatar
Re: Painting Engine
24 Jul 2007 06:44
#159159
Under my cast engine colors is a heavy coat of plumb purple:pinch: It did look good:blink: I have the picture but no negatives to copy on to cd so no posting pics of the bike when it was plumb purple.:(
If you look closly you can still see the purple
  • harm
  • harm's Avatar
  • Tom
Re: Painting Engine
25 Jul 2007 04:08
#159419
This link to my project shows before and after pics of my engine. I power washed it first then scrubbed it with a scotchbrite pad. Then wiped it down with acetone. I used PJ1 engine and case paint. It turned out great! Time will tell how long it will last.
kzrider.com/component/option,com_joomlab...11/id,155230/#155230
Tom
Holland, MI
1980 KZ550 ELR
2011 Concours14
2017 KX450 [/color]
