High Temp black, not high temp enough
  • cuddies
  • cuddies's Avatar Topic Author
01 Jun 2007 13:26
#145532
I sprayed the pipes on my 900 with the highest high temp black I could buy. It's that engine stuff. Anyways, it burned up, smoked, and flaked off within the first 20 seconds. Any ideas as to what to use?
  • KaZooCruiser
  • KaZooCruiser's Avatar
Re: High Temp black, not high temp enough
01 Jun 2007 13:39
#145536
Hi, see you are getting underway.
I don't think you are going to get very far with engine paint.
I did a search for exhaust temperature, and came up with this site:
monitor probes
Apparently exhaust gas temperature can run as high as 2200 degrees. At least the sensors are rated at that.
:cheer:
  • kz700rider
  • kz700rider's Avatar
01 Jun 2007 14:24
#145539
I used grill paint. It worked fine.
  • KZPens
  • KZPens's Avatar
01 Jun 2007 14:36
#145541
You are probably looking for header paint. "Duplicolor High Heat Paint" or "VHT Flameproof" are probably the easiest to find in Autopartstores, both are showing a header on the spraycan.
Don't mistake them for the engine enamel paint it goes to "only" 500 degrees.
  • KZ_Rage
  • KZ_Rage's Avatar
  • Kentucky Bourbon Barrel Ale
01 Jun 2007 15:19
#145545
+1 on the grill paint. Some of the supposed header paints aren't all they are cracked up to be especially on used parts.
1979 KZ1000E1 SOLD!
1984 KZ550F2 SOLD!
2006 ZG1000A6F (Totaled)
2001 ZRX1200R (Sold)
  • kawsakiman
  • kawsakiman's Avatar
01 Jun 2007 15:41
#145549
grill paint don't last unless it's cured in a oven
  • KZ_Rage
  • KZ_Rage's Avatar
01 Jun 2007 16:20
#145555
I'm not following you on that one. What kind of oven/temperature are you talking about? I've never had to do that and it has worked well for me. I just warm the bike and shut it off a few times after painting just to avoid the smoke issue of new paint on headers.
1979 KZ1000E1 SOLD!
1984 KZ550F2 SOLD!
  • KZ_Rage
  • KZ_Rage's Avatar
01 Jun 2007 17:41
#145580
Oh and be sure you use 220 grit to rough the surface and be sure it is clean of grease, etc. Like all paint the secret is in the prep.
1979 KZ1000E1 SOLD!
1984 KZ550F2 SOLD!
  • Fossil
  • Fossil's Avatar
03 Jun 2007 14:46
#145947
VHT Flameproof header paint
  • Jack
  • Jack's Avatar
05 Jun 2007 08:14
#146491
AMEN to that...
79 KZ 1075 MKll
79 KZ 1500 MKll dragbike
Gone but not forgotten:
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
  • Grebnaws Inc.
  • Grebnaws Inc.'s Avatar
05 Jun 2007 08:17
#146496
The Krylon bbq grill paint is working for me, but it's only on being used on plastic. It seemed soft for a few days but it hardened as well as any other spray paint. I was going to black my exhaust with it too but maybe I need to look into the header paint instead.
  • kz700rider
05 Jun 2007 09:38
#146518
As long as it is rated for a high enough temp it should be ok (grill paint that is). I used it on a few bikes . It smoked up , cured itself , and looked like the above pic. Im ok with the results.
