G2 Brake Caliper Paint
  • 76LTD
  • 76LTD's Avatar Topic Author
12 May 2007 20:05
#139563
Anybody ever use G2 brake caliper paint?
I sprayed mine with VHT last winter when I was rebuilding everything. It looked great but disolves at the slightest hint of brake fluid. I am looking for something better. I see G2 and folia advertised as better options.
  • RonKZ650
  • RonKZ650's Avatar
Re: G2 Brake Caliper Paint
12 May 2007 20:15
#139567
Welcome to the wonderful world of repaint. I would highly doubt any brand of paint is any better. Once you repaint, it's going to always be a pain in the ass because it's fragile and wont last even if no harsh chemicals touch it. Brake fluid near repaint???? HA, HA. Good luck with that, don't care what kind of paint you use.
  • Pterosaur
  • Pterosaur's Avatar
12 May 2007 20:48
#139581
RonKZ650 wrote:
Hey '76,
While our esteemed colleague is known far and wide to have hired Pink Floyd's sound truck to blare his brand of pessimism from what seems to be every hill and rooftop, in ain't quite all as bad as that. ;)
Don't have any direct experience with G2, but if it's formulated to be DOT resistant, it's easy enough to check both its formula and track record.
That said, the largest single mistake made when painting items that exist in contact with solvent environments is proper curing of the paint itself.
Perhaps the biggest mistakes being that prep work is iffy, paint is shot one day, given all of one night to set up, then the caliper is slapped back together the next day and fluid gets slopped all over it.
Best thing to do is have the calipers bead blasted, then paint them *immediately*. Let 'em set, then if possible, hard-set the paint using infared lamps if possible, or at the very least exposing them to direct sunlight for several days before starting re-assembly.
It's all well and good for people to make oddball comments about the futility of "repaint" - but that neither makes what are already a crappy set of calipers look better - nor offers much in the way of useful solutions. ;)
  • Pterosaur
12 May 2007 21:08
#139587
Okay, just took a look at: The G-2 Manufacturing Brake Caliper PaintSystem
It's really pretty simple stuff.
They give you a standard can of spray brake cleaner, and a couple of small cans one of a variety of colored enamels and a can of urethane hardener.
Simply stated, this is mixing a thick batch of catalyzed automotive paint, with perhaps some recipe tricks to make it a bit more solvent resistant, you mix the two, brush it on, and the catalyst polymerizes within the paint, making for a pretty tough coating.
Despite their instructions, I'd still do two things; bead blast the calipers - and give it at least 24 hours to set before putting 'em back together.
I'd say there's better ways to do it, but as a simple DIY-type of kit, it'll do okay. It'll be pretty resistant to DOT spills, but I'd wipe away any spillage rather than just let it sit on the fresh paint.
And there you have it. ;)
  • Voodoosoup
  • Voodoosoup's Avatar
12 May 2007 22:55
#139599
I used this stuff on some car calipers a few years back. It held up fine for the couple of years that I had the car after I painted them. It brushed on very nicely and the coverage was great.
  • ronjones
  • ronjones's Avatar
12 May 2007 23:23
#139600
Just a "newbies" opinion, having some recent experience w/ brake master cylinder/caliper repaint...I'm beginning to appreciate the appearance of naked aluminum.:pinch:
  • Pterosaur
13 May 2007 05:14
#139611
Sound enough wisdom - can't peel off what ain't there...
A couple of early-morning thoughts on the stuff:
It's worth noting that the ad itself says nothing about application over aluminum - which makes sense because it's a car caliper kit - and car calipers are generally made out of steel of some sort.
That isn't a deal breaker - and as noted in a previous post, it'll stick pretty well, but there's a couple of things that'll help it:
First, BEAD BLAST the calipers. Plain and simple. A can of brake cleaner and a wire brush just ain't gonna cut it as "prep" for paint. Blasting will take the metal down to a clean, un-oxidized surface - much better for adhesion purposes.
Second, if you *really* wanna get trick, get a small can of ZINC CHROMATE primer - available from aircraft refinishing outfits - blast the calipers, prime 'em with the Z/C, and then apply your paint. Do that, and you'll have a hard time getting the paint off with dynamite.
As stated previously, there's better ways to do it - just a matter of how trick you wanna get. ;)
  • 76LTD
13 May 2007 06:19
#139624
I wonder if powder coating would be better? That for sure is tough stuff. Can it take an occasional brush with brake fluid?
  • Pterosaur
13 May 2007 06:23
#139626
Yep. It'll do just peachy - much better looking - and lasting - than the G2 kit. B)
  • wireman
  • wireman's Avatar
13 May 2007 13:18
#139716
what the squirrel saidB) i used to have really good luck painting parts with dupont imron,but its about impossible to find anymore with all the epa crap;) dot 5 brakefluid helps also;)
  • wireman
  • wireman's Avatar
13 May 2007 13:51
#139727
oh yeah,hey ron!have you got a phone number for the pink floyd sound crew?ive got a birthday coming up and would love to have david gilmour show up !:evil: :P
