gas tank repair
- peterc
gas tank repair
25 Apr 2007 16:19
In the last few months i bought a 1983 kz750E,i just finished cleaning the carbs(6 hours worth)and moved on to the gas tank.I found a screw and washer in the verry bottom that was sealing a leak,the gas cap would not open but with a little work i got it open the pin under the lock was broken and i will replace or make a new one.On the inside of the tank i noticed it had ben sealed with a pinkish creamy colored epoxy type material.The question is does anyone know what this might be? I have heard about sealers for tanks but have not used them before.other than were the screw was the rest of the tank looks solid ( i striped the paint to bare metal) any help would be a great help thanks.
- wireman
Re: gas tank repair
25 Apr 2007 17:23
yeah its probably some kind of tank sealer.can you post a picture of where the screw is at?
- peterc
Re: gas tank repair
25 Apr 2007 17:34
my camera is dead sitting on the bike 3/4 way back on left side 3/8 inch up from the seam.
- peterc
Re: gas tank repair
25 Apr 2007 17:42
I was going to replace the tank but the last 4 i have looked at were in worst shape than mine hopeing i can fiberglass patch the hole and re coat the inside.with the stuf that is in there now it looks pretty clean.as i mentioned i cleaned the carbs they had alot of rust sediment in the bottom of the bowls.I think the tank was the problem.
- wireman
Re: gas tank repair
25 Apr 2007 17:54
i dont know about fiberglass . id remove the screw and rough it up really good in an area a couple inches bigger than you need and put a little ding where the hole is then i would either solder it up or find some gas resistant epoxy to fill it in with;)
- peterc
Re: gas tank repair
25 Apr 2007 18:07
thanks for the reply the epoxy is a good idea do you know ware i can get the sealer? and is there any know if i can buy a replacement gas cap mine is junk i could fix it if need be but the crome is rough to.It is rectangular in shape my 83 LTD has the same one on it.
- wireman
Re: gas tank repair
25 Apr 2007 18:18
auto parts store should have some epoxy that will work,put it on smooth as possible to save you some sanding;) im not sure if you can put sealer over sealer.if inside of tank is clean and not flaking id just run it;)
- Leather
Re: gas tank repair
05 May 2007 16:54
If its pinkish white then more than likely it KREEM a brand of takn sealer. I'm with the epoxy sealer if possable.. theres a couple of them that are a two part putty you mix and press in to holes to seal up car tanks with holes. Might look for some of that.
- JMKZHI
Last edit: 03 Dec 2008 11:14 by JMKZHI.
