fender exchangability
- oldkaws4ever
- Have no regrets...... You only live once.
18 Apr 2007 02:07
will the front and rear fender from a kz 100, fit a 74 z1 900?
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
- wireman
Re: fender exchangability
18 Apr 2007 05:33
im not sure about a kz100 but a kz1000 should fit;)
- Shoe48
- Live each day as it is your last
18 Apr 2007 06:04
What I ran into with my KZ project was the bolt holes line up fine BUT if the fender came off a set of forks that had its axle in front of the tubes the fender mounts are mounted differnet than if the fender came off a set of fork tubes that the axle was mounted at the bottom .. the center of the fender is off to compansate for the axle in front ,, Makes the fender fit close at the rear of the tire and not centered
- oldkaws4ever
18 Apr 2007 14:33
my bad i mean a kz 1000:whistle: :blush:
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
- wireman
18 Apr 2007 14:52
oldkaws4ever wrote:
73-80 z1-kz1000 should interchange;)my bad i mean a kz 1000:whistle: :blush:
