My new paintwork
  • ronjones
  • ronjones's Avatar
Re: My new paintwork
17 Apr 2007 10:44
#131125
Really nice looking tank. I'm in the process, under PT's tutelage, of using the PJ1 epoxy clear coat on my tank. Gotta say it's turning out real nice. Much better than the clear I'd originally put on it.
Ron
BTW let it dry for at least a week before doing anymore on it. Ya think it's dry early and then ya procede to find soft paint under the hard shell. Trust me, I've done it more than once. Luckily the weather is stopping me from messing w/mine before it's fully cured.
  • tganek
  • tganek's Avatar
17 Apr 2007 10:54
#131135
WOW! Looks awesome! Can't wait to see the finished product.
  • Wirewulf
  • Wirewulf's Avatar
17 Apr 2007 11:22
#131151
Me rikeeeee! Reminds me of my friends' '79? Duc 900SS scheme. BTW the side panels on that are all black and look slick. It also carries the stripe on the front fender.
  • Pterosaur
  • Pterosaur's Avatar
17 Apr 2007 11:55
#131168
Fourtoes wrote:
DOes PJ1 come in a rattle can????
Yep.
Here's a link that shows a fair part of their lineup of colors/uses: solomotoparts
Hopefully, it's available over in the Misty Isles. ;)
Post edited by: Pterosaur, at: 2007/04/17 14:58
  • beardog63
  • beardog63's Avatar
17 Apr 2007 16:16
#131268
nice work go with the satin clear
  • Fourtoes
  • Fourtoes's Avatar Topic Author
17 Apr 2007 16:18
#131270
IF and thats a BIG IF I can find it in the UK.
Can find the gloss but thats it. For $11.
  • ltdrider
  • ltdrider's Avatar
17 Apr 2007 16:30
#131275
Fourtoes:
Your paint job looks awesome.
Most clear coats for sprayers are made to be applied within 24 hours. This helps the bonding process between the base and clear coats.
Since you're using paint from a rattle can, I don't know how long you can wait between the base and clear coat. You should ask someone that knows.
'76 KZ900 LTD (Blaze)
'96 Voyager XII (Dark Star)
Greensboro, NC
  • wireman
  • wireman's Avatar
17 Apr 2007 16:41
#131277
im no master painter by any means but in my experiance its best to let paint set up as long as possible like a week or more is no big deal so it can have plenty of time to shrink or whatever its going to do,then rinse it off with cold ass water and let it dry really good and then clear it.
  • Pterosaur
17 Apr 2007 16:53
#131281
No, COLORCOAT/CLEARCOAT automotive paints are designed for production work - and work incredibly well due to quick-set reducers.
Excuse me, but in a word - horseshit.
It's done within 24 hours because it's "set" for practical purposes.
And even so - clearcoats shot 24 hours after colorcoats are only applied after a light wet-sanding with #1000 grit.
The longer the better.
I dunno - does *this* qualify?
A two tone color/clearcoat shot within 24 hours.
Just happened to own a body shop for over 30 years. ;)
  • duncan
  • duncan's Avatar
17 Apr 2007 17:20
#131287
very nice job. what color is the paint...satin black? charcoal? it looks much richer than the semi-gloss black on my bike.
FYI, there's a spraymax 2 part clearcoat here, but it seems to be available only in high gloss, not satin:
www.belton.de/en/EngFrameset.htm
(click 'automotive' on the left, then 'spraymax' on the right )
it shows up on this site too, but says its currently unavailable:
achuka.co.uk/amstore/search.php?query=spraymax&mode=all
(it's available at amazon.com in the USA.)
Post edited by: duncan, at: 2007/04/17 20:22
  • Pterosaur
17 Apr 2007 17:54
#131296
For purposes of clarity - most any base color automotive enamel will be shot with a urethane additive - which makes the setting process partially by sublimation - the evaporation of reducers - and partly a *polymerization* of the two-part urethane catalyst - which is why the base coat is set for PRACTICAL PURPOSES within 24 hours.
A urethane clearcoat is essentially the the same chemically as the additive used in base paints, with some minor recipe variations for UV opacity and whatever other considerations a given manufacturer considers important.
Clear coats flow into and adhere to the surface of the underlying paint, but aside from some minor chemical binding due to the "thinning" characteristic of the clearcoat being applied, the two layers remain distinct in composition - they in no way "merge" or chemically interact with each other in a significant way.
Since rattlecan paints contain NO urethane additives to aid the setting process, their final set is determined solely by sublimation. As a result, rattlecan paint requires longer to set. Period.
The only way to reasonably modify that time frame is by infa-red heating - either by booth, lamp - or in the shadetree application, sunlight.
Thus - as has been noted elsewhere, a rattlecan paint job will shrink some noticeable amount as it sets.
The longer a rattlecan job is allowed to set, the more of its final shape will have been achieved before sanding for clearcoat application.
Answer the question? ;)
B) ;) :unsure: :dry: :ohmy: :woohoo:
  • ronjones
  • ronjones's Avatar
17 Apr 2007 19:05
#131325
Man PT, is that the same stuff I'm using? I don't think mine has finished setting and I'm already seeing reflections, the "peel" is smoothing out each day. It's on day 4 right now. Hope mine turns out half as nice as those, after I do my final buff:)
