Engine paint
  • mark1122
  • mark1122's Avatar Topic Author
  • Keep twisting it
Engine paint
03 Apr 2007 16:00
#126240
Anyone have trouble with Dupli color gloss black engine paint chipping? I tried Duplicolor’s high heat paint on my head after glass bead, thinner, and an acetone bath. But it seems to be too thick and chips too easy. I found it dificult to get coverage in all the nooks and crannies so I kept spraying and it did end up pretty thick.Does the semi gloss spray on thinner ? Or is there something better I should use ? I an going to have to reblast I think?:angry:
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • wireman
  • wireman's Avatar
Re: Engine paint
03 Apr 2007 16:08
#126243
i aint ever had luck getting anything to stick to an aluminum cylinder or head.maybe try preheating head,then baking head in the sun afterwards .dont bake painted parts in wifes oven dont ask me how i know!:blush: :whistle: :woohoo:
  • mark1122
  • Keep twisting it
Re: Engine paint
03 Apr 2007 16:12
#126245
I just waited till she was out then snuck it into the oven.:P
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • wireman
  • wireman's Avatar
Re: Engine paint
03 Apr 2007 16:17
#126249
i did that years ago in an apartment with some aluminum boat headers i painted!:blink: :P
  • mark1122
  • Keep twisting it
Re: Engine paint
03 Apr 2007 20:02
#126299
Did you get caught?:P :woohoo: :angry: :side:
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • wireman
  • wireman's Avatar
Re: Engine paint
03 Apr 2007 20:10
#126302
by everybody in the damn building!:blush: :woohoo: :silly: :woohoo: :silly: :woohoo: :silly: :woohoo: :silly: :woohoo: :silly: :pinch: :P
  • Mark Wing
  • Mark Wing's Avatar
Re: Engine paint
03 Apr 2007 22:07
#126320
I've had good luck with the simi-gloss. Start painting the hard to get areas first then get the rest.
Mark
Post edited by: Mark Wing, at: 2007/04/04 01:15
Yorba Linda Cal.
  • mark1122
  • Keep twisting it
Re: Engine paint
08 Apr 2007 20:23
#127942
I'd like to hear from all that have had success painting your heads and blocks. What did you do for prep work? Sand blast or glass? types of cleaners used before paint? Type of paint? How long has it lasted? Thanks I'm In a bit of a pickle over paint or not now, since I have 1 faild attempt.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • Mandrake
  • Mandrake's Avatar
Re: Engine paint
10 Apr 2007 10:52
#128533
I'll add my $.02. When using any spray-can product you will be somewhat limited due to the properties of the coating and solvents that are used. Be sure that they recommend their product specifically for aluminum. It also might be worth using a high-temp primer first. Investing in a basic spraygun will give you many more options when it comes to coating selection for engines. A decent little gravity fed unit will do the trick and can be had at Sears or HD for $50.
As far as blasting goes you should get better adhesion with a "sharper" abrasive. Glass beading seems to do a good job, particularly with cleaning, but you might consider a fine sand, garnet, coal-slag, or something like an aluminum oxide. Call your local blaster and ask what they have.
Finally, be careful in handling a cleaned piece. Oil from your hands can prevent good adhesion in certain spots. A pair of cotton gloves should solve the problem.
BTW - can anyone recommend a good set-up for blasting small pieces?
  • Pterosaur
  • Pterosaur's Avatar
Re: Engine paint
10 Apr 2007 11:02
#128537
Mandrake wrote:
I'll add my $.02.
What Mandrake said. ;)
My only nit is my experience with using sand as a blasting medium for anything aluminum - the grains tend to shatter and embed themselves in the aluminum pores, leaving a dusty, "dirty" surface that needs additional handling/cleaning between blasting and application stages.
My best results were always bead-blast, blow it off, shoot your primer/paint and you're outta there. B)
  • mark1122
  • Keep twisting it
Re: Engine paint
10 Apr 2007 14:24
#128584
Thanks .I just shot the head with aluminum oxide and I will try again on the week end.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • duncan
  • duncan's Avatar
Re: Engine paint
10 Apr 2007 14:26
#128586
as far as engine paint goes, z1enterprises carries this one:
www.z1enterprises.com/detail.aspx?ID=1752
maybe give jeff a call to see if he has any first hand experience with it.
