good cutting aluminum polish
  • brawnyrebel
  • brawnyrebel's Avatar Topic Author
24 Mar 2007 09:17
#123088
I used some oven cleaner to degrease my engine while i have it out of the bike. It did a real number on my side covers and mothers polish will not bring it out. Is there a high grit polish or something that may take care of it? Its that or they go to the powder coaters
  • katjbus
  • katjbus's Avatar
Re: good cutting aluminum polish
24 Mar 2007 09:21
#123090
you will probably have to start with some fine grit sandpapers and work your way to the mothers
  • Pterosaur
  • Pterosaur's Avatar
24 Mar 2007 09:39
#123095
Most likely, depending on how scratchy things got.
A pic of the covers would help get a better idea of what's really needed.
Simichrome seems to have a higher grit content than other polishes.
A pretty well done thread on polishing:
Home polishing, how and what do you need?
  • brawnyrebel
24 Mar 2007 09:51
#123100
I'll try to get a pic up later. There aren't really any scratches, it seems like the ovencleaner just forced dirt down into the pores of the metal.
  • Pterosaur
24 Mar 2007 10:30
#123105
Cool.
Prior to going ape with Mother's/Blue Magic/Simichrome, etc., the best stuff I know of for pre-polish cleaning aluminum without gobs of grit, perfume, food coloring and whatever else they shovel into the vat is plain old brake cleaner. Breaks down grease, dirt and the associated gunk in a jiffy, evaporates in a hurry without leaving a tacky residue. $1.98 a can at most AutoMart (tm) type stores.
Big issues with it are fumes - ventilate well, and get some cheapo rubber gloves.
Used in conjunction with a soft brush - an old toothbrush is perfect - and a wipe-down rag, the results 'll downright amaze you. ;)
And you don't have to apply it with a fire hose - wet down a small area, brush it, wipe down, rinse with a little more cleaner and another quick wipe.
Repeat, move around as necessary. B)
Post edited by: Pterosaur, at: 2007/03/24 13:35
  • Mark Wing
  • Mark Wing's Avatar
24 Mar 2007 10:40
#123106
Some 2000 grit sandpaper should cut through it then mothers will do the rest.If you have to you can start with some 1000 paper. You can try some automotive rubbing compound, it's got some grit to it.
Mark
Yorba Linda Cal.
  • brawnyrebel
25 Mar 2007 05:56
#123264
I'll get some sand paper out later and start with a shot of brake cleaner and see how it goes. i'll snap some shots first
  • brawnyrebel
25 Mar 2007 17:20
#123406
I did a bit of sanding on the covers today. The 1500 grit got them looking better than they did before they got the oven cleaner on them but i'm still not compleatly done
  • Pterosaur
25 Mar 2007 17:33
#123410
Stick with it:
You can get really spiffy results with practice and an idea what you're looking to do.
It's entirely possible to polish aluminum to a mirror finish, but sometimes it isn't the desired effect; in the shot above, the object was to make 'em as clean as possible, but leave enough of a buff on 'em to approximate the best-possible "factory" look. ;)
  • neilage66
  • neilage66's Avatar
25 Mar 2007 19:36
#123460
What was the name of that product that KZ250LTD (Tim) was using on his fork legs awhile ago? I can't think of the name, but his photos showed great results.
ps: That shot of your motor/engine (take your pick) is a goodun PT. :)
  • Pterosaur
25 Mar 2007 19:58
#123471
Thanks.
If yawanna go nuts for shine, it really doesn't take any "miracle polish" - if there is such a thing - here's a shot doen with various grist of paper, glass cleaner, Turtle Wax polishing compound, Blue Magic polish - and elbow grease. ;)
B) ;) :unsure: :dry: :cheer: :silly:
  • neilage66
26 Mar 2007 18:53
#123755
Yowza, them's spiffy! :)
