Seat lock
  • 82_twin_KZ
  • 82_twin_KZ's Avatar Topic Author
Seat lock
06 Mar 2007 13:07
#117807
I have a 82 kz750 twin that i just bought. How does the seat lock and helemt lock work? I have tried to unlock it with my ignition key but it does not work. The ignition key work in the ignition. Is there a different key to open the seat and helmet lock?
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
Re: Seat lock
06 Mar 2007 13:25
#117812
You could try spraying some WD40 into the latch locks...with luck they may simply be gummed-up from lack of use. HOWEVER, most likely, is that the PO put a new ignition into the bike because he/she lost the keys (or did not have them, for whatever reason). So, if that is the case, then you will have to pick the locks and replace them with ones that come with keys (to be found on eBay).
EDIT: You also need to read this recent link to another thread on similar problems tinyurl.com/295ztp
Post edited by: Mcdroid, at: 2007/03/06 16:35
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • 82_twin_KZ
Re: Seat lock
08 Mar 2007 11:18
#118402
thanks for the info
  • ronjones
  • ronjones's Avatar
Re: Seat lock
08 Mar 2007 13:36
#118430
If all your locks are stock, a single key should open all 5 locks...ignition, seat, gas cap, and both helmet locks. If a PO has had to replace one, or more, of the locks then that key would not work on the other locks. Which locks will the key, you have open? If you only have, say, the ignition key and the ignition lock has been replaced, then it probably won't work on the other locks. I had to replace my gas tank lid so I now have to deal w/2 keys.
Hope this helps
Ron
  • Biquetoast
  • Biquetoast's Avatar
  • King Jeremy The Wicked
Re: Seat lock
08 Mar 2007 18:03
#118502
I don't know if the later twins had key numbers stamped on the face of the locks (mine do), but it's worth a look. Take a real close look, the numbers are pretty small... at least if you had that, you could get replacement keys...
(1.) '75/'76 KZ400D - Sold
(4.) '75 KZ400D - Sold
kz750twins.com
  • austin3119
  • austin3119's Avatar
Re: Seat lock
08 Mar 2007 18:06
#118503
My ignition went bad on my KZ900 so I replaced it. Now I have 2 keys, one for the ignition and one for everything else. That's probably what happened with the po.
  • 82_twin_KZ
Re: Seat lock
14 Mar 2007 18:33
#120231
My key also unlocks the gas tank.
  • Biquetoast
Re: Seat lock
15 Mar 2007 06:32
#120335
The gas caps on the old bikes aren't really *keyed*, per se. They can be opened with a thin screwdriver...
kz750twins.com
