What type of paint is on my bike
- FireBurst
02 Dec 2005 05:13
I am planning a repaint this winter and need to know what is on there.I think it is the original paint. There is a clear coat on it,fine grit sandpaper made white dust. How do I test the color below?
- ltdrider
Re: What type of paint is on my bike
02 Dec 2005 06:48
Kawasaki used acrylic lacquer in the '70s. It was a three-step process... base coat, color with metal flake, clear coat.
Lots of members have repainted, and others will jump in with advice, but I think new paints are more durable than the original, and also more resistant to gas. Lacquer is not legal in California anymore, so a 'professional' body shop or paint shop won't use it.
'76 KZ900 LTD (Blaze)
'96 Voyager XII (Dark Star)
Greensboro, NC
Greensboro, NC
- mykznme
02 Dec 2005 08:20
FireBurst wrote:
simply dab some water on the sanded area if you can visibly see white scratches through the water then you need to use a finer paper.
if your just going to reclear 240-300 grit should be fine C:\Documents and Settings\jne\Desktop\P1010092.JPG
R.I.P. Odd Ivar
- FireBurst
03 Dec 2005 14:50
I tried rubbing the paint with lacquer thinner but that had no effect. If it was a lacquer it should have come off on the rag. Or is that not how you would test for that.
- mykznme
03 Dec 2005 14:53
make sure your all the way through to the color.
if the dust is white then its still clearcoat6
R.I.P. Odd Ivar
- tweakin_82
05 Dec 2005 03:13
If you are using laquer thinner make sure that you let it sit on there long enough.
- guitargeek
05 Dec 2005 11:45
1987 KZ1000-P6 "Ponch"
1979 GS1000 "Dadzuki"
