Electrolytic rust removal
  • oldcoldankles
  • oldcoldankles's Avatar Topic Author
18 Feb 2007 09:51
#113327
I found these these rust removal links on another forum. One of the guys reported using it to remove rust from the inside of Kawasaki gas tanks. He reported it took a few days soak sometimes but the results were definitely worth it. To clean the inside of a fuel tanks, they filled it with the solution and dropped the anode into the tank making sure it doesn't touch the sides. They used a long bolt stuffed through the center of a cork to do the tanks.
Anyone tried it?
antique-engines.com/trailer-electrolysis.htm
antique-engines.com/electrol.asp
Post edited by: oldcoldankles, at: 2007/02/18 13:09
Peachland BC
1981 KZ1000 CSR M1
1983 KZ550 LTD M1 (Shaft)
1989 Corvette coupe
  • Biquetoast
  • Biquetoast's Avatar
  • King Jeremy The Wicked
Re: Electrolytic rust removal
18 Feb 2007 11:06
#113338
oldcoldankles wrote:
Anyone tried it?
Yep, I have. And it works very well on rust. But I've said it before and I'll say it again - make absolutely sure there is nothing in the tank other than rust! I had some varnished fuel spots in mine that protected the surface from the electrolysis and now I have spots on raised rusty surfaces... Remember, this process is REMOVING the metal surface of the tank, so be feaking careful....
(1.) '75/'76 KZ400D - Sold
(4.) '75 KZ400D - Sold
kz750twins.com
  • KZQ
  • KZQ's Avatar
  • Administrator
  • Administrator
18 Feb 2007 15:21
#113398
I tried it with salt water and it didn't work at all. I've read about using caustic soda but havn't tried it as yet.
If you really want to clean your tank and don't want to spend days doing it follow this link.
kzrider.com/content/view/22/11/
Works every time no matter how much rust you have.
Bill
KZCSI
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
  • arobsum
  • arobsum's Avatar
19 Feb 2007 19:21
#113714
look in the engine section. there is a thread with pics and instructions showing this process with good results.
