Custom See Thru clutch cover NOW WITH PICS! UPDATE 1-11-06
  • wireguy
  • wireguy's Avatar
Re: Custom See Thru clutch cover!
10 Dec 2005 19:46
#12566
looks neat,but i was just wonderinghow it holds up.does oil discolor it over a period of time?
The topic has been locked.
  • Kawozaki
  • Kawozaki's Avatar
18 Dec 2005 10:49
#13654
Hey TWT...Any progress? Still wonderin' how you made out on this project.
Oz
  • twowheeledterror
  • twowheeledterror's Avatar Topic Author
18 Dec 2005 11:18
#13655
Oz
I'll come out of hiding to post pics when I get them taken and stuff. lol
  • twowheeledterror
11 Jan 2006 12:03
#17273
Okay, I got it cut now. Here's the pics.
(I'm aware the cut is smaller than planned... this is for mounting purposes.)
Post edited by: twowheeledterror, at: 2006/01/11 15:42
  • twowheeledterror
11 Jan 2006 12:48
#17279
Pics on the engine, just to see how it looks. I think it's perfect. :D
  • twowheeledterror
11 Jan 2006 13:21
#17280
Photoshop with colored basket.
  • cudaosix
  • cudaosix's Avatar
11 Jan 2006 16:34
#17305
Thats coming out real nice twowheel. Looks great.
  • kwakagoose
  • kwakagoose's Avatar
11 Jan 2006 19:11
#17345
That's cool B)B)B)
  • KzJim
  • KzJim's Avatar
12 Jan 2006 04:10
#17418
Looks sweet!... keep me posted... im interested.
Naiveté in grownups is often charming, but when coupled with vanity, it is indistinguishable from stupidity.
Tis better to remain silent and thought a fool - than to speak up and remove all doubt.
Did ever think that maybe you've been doing it wrong all these years?
  • wiredgeorge
  • wiredgeorge's Avatar
12 Jan 2006 06:56
#17442
Personally, if I were going to cut a hole in the clutch cover, I would bevel the edge and bevel the edge of the clear plastic (not sure what you chose to use). The bevel cut would provide mechanical strength if there was pressure put on the plastic so the bond would not just rely on the strength of the epoxy.
I don't know much about plastics but some of them are affected by oil so you want to do some research and find out which are not going to get discolored and post this info...
Last, I recommend looking into golf club repair epoxies. The strongest epoxy (highest sheer strength) is that used to put the plastic face inserts into wooden clubheads. There is so much chance of litigation for professional clubmakers, that this epoxy is extremely tough and virtually impossible to remove (once set) without heat from a torch. It has much higher strength and longer cure time than does the epoxy used to retain the shafts to the heads. I have not found anything similar in autoparts stores, etc.
  • twowheeledterror
12 Jan 2006 18:32
#17587
I'll post my research as I go in terms of which materials will work best. I'm gonna call some manufacturers and ask them what they recommend.
As for the bevels, it's impossible. The cover is very thin. Not enough to actually bevel it much. :(
  • ronboskz650sr
  • ronboskz650sr's Avatar
13 Jan 2006 13:07
#17738
If you opened it up just to the beginning of the first rounded edge of the casting, there would be a little more material to bevel as the casting changes angles there, and you'd expose more of the mechanicals at the same time. Just a thought.
