Everyone seems to like drag racing....
- caffcruiser
08 Dec 2006 20:50
But what about us "canyon carvers".
I've seen PLENTY of threads about how to stiffen up a frame for serious power... so I figured that it might be kinda cool to start a different kind of chassis thread.
Let's call it:
"HOW ARE YOU MAKING YOUR BIKE HANDLE AWESOME?!?!"
Mine?
-GSXR 750 standard telescopic fork.
(Chose not to go inverted. The standard early 2000's fork is immensely adjustable, and has better handling than most people realize... better in some respects than an inverted fork in terms of rigidity when mated up to our 30 year old frames!
-2005 Yamaha R6 rear end with arm and shock, linkages, etc.
-40 spoke Excel 3.5 and 5.5 front and rear wheels.
-GSXR front calipers/rotor assemblies
-R6 rear caliper/rotor
-Posture. I'm keeping the back end somewhat higher.
Let's call it:
Mine?
- solomrus
Re: Everyone seems to like drag racing....
08 Dec 2006 21:18
not building huge power, just a mild 1197.
frame will be gusseted some, but it sounds like i am building a similar combo.
05 636r front end
05 636r swingarm/linkage/shock
05 636r front and rear wheels/brakes
i went with the 636 parts mainly for looks, as i can't tell the difference between a bike that handles well and one that just handles. 8^)
i am hoping for decent ride quality, maybe a little better handling than stock, and most definitely brakes from the current decade.
i've everything, save for the wheels and brake rotors now. those i am planning on having in the next week or so.
the spokes that you are setting up for your bike sound cool. black hoops or bare?
--r
05 636r front end
--r
198o kz1ooo Bravo Four
- scumbag
- Lewd, Screwed, and Tattooed
08 Dec 2006 21:20
duct tape and bailing wire...oh and a pocket full of pomade and a cheap black comb..thats how I get around them corners...
but really...newer harly rear shocks that are 13.5 to raise the rear up a bit and keep things stiff...inch anc a quarter pvc spacers in the front forks with 20 weight oil seem to make the front end a little more race'ish...oh and dropping the forks about a inch or so in the triples to steepen up the rake and give a little quicker steering...
all in all not quite as drastic as my friend Caff but simple and cheap...
sept.1976 kz650
1980 kz650
1980 kz650
- caffcruiser
09 Dec 2006 02:29
solomrus wrote:
Aluminum standards, no paint.
I'm thinking the hubs will be painted though....
--r
- Samwell
09 Dec 2006 03:04
I'm with you. Spiritedriding down the small two lane roads beats drag racing or even droning along the interstate.
You seem to have attacked the problem more vigorously than I did.
So far:
>new tapered steering head bearing, progressive springs and new fork oil.
>dilled ebc rotors and steel braided lines all around (dual calipers but the original ones!)
Things I'm considering over the life of the project:
>cartridge fork emulators
>excel rims: just a little wider than stock, 2.15 front and 3.00 rear. Should give me more rubber for good contact but not change the ride too much.
Sam
So far:
Sam
Let's call it:
Mine?
(Chose not to go inverted. The standard early 2000's fork is immensely adjustable, and has better handling than most people realize... better in some respects than an inverted fork in terms of rigidity when mated up to our 30 year old frames!)
- kwakagoose
09 Dec 2006 07:15Please Log in or Create an account to join the conversation.
- mark1122
- Keep twisting it
09 Dec 2006 07:21
Working on adding zrx12 rear end and zx12 front.Lots of gussets.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- CoreyClough
- GPz550 Addiction
09 Dec 2006 07:44
I might not ever race, but investing in a track day, is a for sure thing in my future. I completely agree with what's been said above, that a squiggly line on a map is far better than a straight line to me anyday. Not for speed, but the work-out involved, and focusing into the next corner.
Freeway on-ramps are a great mini dragstrip, but don't make up for one. Accelerating full throttle while tucking, as you toe-down into another gear is a great feeling. You gotta try it, besides it a good way to measure you and your bike's horsepower.
Backroads rule!!!
Adjusting one's suspension(if applicable) makes a difference as well. Min'e all stock, and adjustable, but I haven't messed with it from where it sits. This, too, is in the works for the future.
Post edited by: CoreyClough, at: 2006/12/09 10:46
Backroads rule!!!
'85 GPz550(ZX550-A2)
- wireman
09 Dec 2006 08:29
solomrus wrote:
id say the frame gusseting would be about the same.id try and find a good stiff swingarm about same length as stock if you want to be a canyon carver but be carefull taking rake/trail out of frontend without adding a steering stabilizer.the problem with nebraska and iowa is we dont have anything to compare with a mountain road or the cost highway in california so its pretty hard to outdo a slightly modified stock suspension in a corner,but we do have some really long stretches of nothingness for long blasts thouugh!:evil:
Post edited by: wireman, at: 2006/12/09 11:38
brakes from current decade,you suck !wheres your sense of adventure?:evil:not building huge power, just a mild 1197.
05 636r front end
--r
- 77KZ650
09 Dec 2006 09:08
Braced frame, and read sig;)
Scott
Scott
07 MDP Rookie of the Year
- caffcruiser
09 Dec 2006 09:10
wireman wrote:
Well that and your main freeways not having any corners from one side of the state to the other.
:woohoo:
- wireman
09 Dec 2006 09:33
caffcruiser wrote:
well we do actually have a couple curves but they all have stop signs on them,between that and the amish folk it is a little complicated!
ah youve obviously been here before!wireman wrote:the problem with nebraska and iowa is we dont have anything to compare with a mountain road or the cost highway in california
Well that and your main freeways not having any corners from one side of the state to the other.:woohoo:
