Rear brake adjusting
- kzwolfsr
08 Dec 2006 11:46
I tried adjusting my rear brake lever play and when I loosen those 2 nuts on the bottom the rod doesnt move, like its stuck or something. I s there any trick out there that I have to do or is there something I am missing?
Original man of the Caribbean
- wiredgeorge
Re: Rear brake adjusting
08 Dec 2006 17:14
I am confused too... your brake lever actuates the front caliper(s) and the rear brake is actuated using a pedal... regardless of whether it is a disk or drum brake. Please clarify.
- kzwolfsr
09 Dec 2006 16:27
I am sorry I meant the pedal for the rear brake, and by the way I took of my head and you could be right about valve clearances
- kzwolfsr
11 Dec 2006 11:25
Not to worry I realised I skipped an important line in the manual lastnight about turning the pushrod
