Winter storage
  • Alex_KZ1K
  • Alex_KZ1K's Avatar Topic Author
Winter storage
23 Nov 2005 09:07
#9824
Somebody told me to keep the weight off the suspension and tires... is that really that important? I only ask because I don't have a center stand and I'd have to try and figure out a was to lift it and keep it up safely without the risk of something giving way and the bike falling over.
  • cudaosix
  • cudaosix's Avatar
Re: Winter storage
23 Nov 2005 09:15
#9825
Flat spots can form on your tires from the weight of the bike and sitting in one position over a long period of time. Finding a way to keep the tires off the ground and letting out some air is a good idea.
You can find a centerstand on ebay for cheap Redlinecycle.com will sell you one with the mounting bolts in excellent condition for around $30. Ebay will be the cheapest way to go, either way its money well spent since the stand is handy for other things.
Post edited by: cudaosix, at: 2005/11/23 12:19
  • wireguy
  • wireguy's Avatar
Re: Winter storage
25 Nov 2005 16:36
#10227
if you move the bike aroud occasionally flat spots shouldnt be a problem.i reccomend topping off the gas tank,if you dont rust can formin the tank in the area with no fuel and drain the carb bowls to keep varnish from forming.i also like to crank the engine over once in a while you dont have to start it,just turn it over a little.this keeps thing lubed up and takes some pressure off the valve springs by not having the same valves open all the time.
  • duncan
  • duncan's Avatar
Re: Winter storage
25 Nov 2005 16:50
#10232
i hear it's a good idea to avoid oxygenated gasoline in the tank for winter storage, cause any condensation can lead to separation of the gasoline and alcohol/water:
www.chevron.com/products/prodserv/fuels/...-nona/concerns.shtml
(so i don't fill up at sunoco immediately before winter storage.)
Post edited by: duncan, at: 2005/11/25 19:51
  • KZQ
  • KZQ's Avatar
  • Administrator
  • Administrator
Re: Winter storage
25 Nov 2005 17:18
#10237
Another problem with so called oxygenated fuel is the alcohol can and will attack the natural rubber parts like the seals in your petcock. I like to add a big dose of fuel dryer to a tank of gas because I think the bike runs better on it, but I've learned the hard way to be sure I burn it all out in one day. If I park the bike with alcohol in the gas for any extended length of time I can barely get the petcock to open when I'm finally ready to ride.
KZCSI
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
  • Alex_KZ1K
Re: Winter storage
25 Nov 2005 22:25
#10266
Crap.
That's the last place I filled up...
Oh well, I had planned to drain the tank into my car's gas tank before the storage anyways, the body panals are getting a fresh coat of paint during the winter. As for the suspension weight, I'm still trying to devise a method of lifting the front and the rear of the bike without risk of it falling over. I think I'm going to have to remove the pipes...
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
Re: Winter storage
26 Nov 2005 03:11
#10274
Alex_KZ1K wrote:
[quote As for the suspension weight, I'm still trying to devise a method of lifting the front and the rear of the bike without risk of it falling over. I think I'm going to have to remove the pipes...[/quote]
Go to Sears, buy a motorcycle jack/lift = US$79.00...perfect for an LTD w/no centerstand (but you still have to remove the pipes).
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • Alex_KZ1K
Re: Winter storage
26 Nov 2005 09:50
#10332
The American Sears has it on sale for $59.99 right now. Here in Canada, it's $159.99... same price as every where else here. Too much money IMO.
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
Re: Winter storage
26 Nov 2005 16:07
#10394
How about a home made wood stand?
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
  • Alex_KZ1K
Re: Winter storage
26 Nov 2005 16:11
#10396
Rob, that's awesome!
I just bought four small (3-ton) jack stands at Princess Auto today (they were on sale for $15 per pair), that will work well enough.
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
Re: Winter storage
26 Nov 2005 16:12
#10397
Look in the filebase section under not model specific. Second page I think is a file for a 650_Bike_stand with a how to with dirrections and materials list.
Just saw your above post. That'll work as well. I use 2 jack stands and my centre stand to keep both wheels off the ground.
Post edited by: rstnick, at: 2005/11/26 19:15
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
  • Alex_KZ1K
Re: Winter storage
26 Nov 2005 16:21
#10399
I'll check that out.
I would have only had to use two stands if I had a center stand. :S:
