shock dimensions
  • wireman
  • wireman's Avatar Topic Author
shock dimensions
05 Dec 2006 21:22
#97737
need dimensions for bottem clevis on suzuki type shocks like the ones used with 1100e swingarm ;)
  • wiredgeorge
  • wiredgeorge's Avatar
Re: shock dimensions
06 Dec 2006 05:44
#97774
Which measurements do you need? I have a Suz swingarm and shocks in my shop.
  • wiredgeorge
06 Dec 2006 09:32
#97819
The mount on the swingarm is about 20mm wide. It is about 33mm high. The bolt hole is in the middle.
It uses a 10mm x 40mm 1.25 pitch bolt that threads into the clevis on the bottom of the shock on the inside hole which is threaded.
The clevis on the shock is 40mm top to bottom but the inside part that fits over the mount on the swingarm is 35mm. It is about 22mm open from front to back
  • wireman
06 Dec 2006 12:17
#97851
thanks george i also need to know the distance from center of hole to top of swingarm where shock mounts so i know where to drill my holes;)
  • wiredgeorge
06 Dec 2006 15:37
#97886
The hole is in the middle of the bracket on the swingarm. The opening in the clevis is 35mm. I would guess at half of 35mm. If you can wait for tomorrow, I will measure to be positive. You also have a bushing in the part on the swingarm.
  • wireman
06 Dec 2006 16:42
#97900
my bad,i need the distance from center of shock bolt hole to top of swingarm so i know where to drill shock bolt holes .ive already got the axle slots milled in 1/2" farther up than center of arm to lower rear of bike more.it has always driven me nuts that the only way to get one of these bikes really low is to have rear of swingarm higher than front of swingarm so i raised mine up.;)
  • wiredgeorge
06 Dec 2006 19:01
#97932
I am kind of confused as to what you need. This pic shows a typical Suzuki swingarm with mount bracket for clevis on shock... show me what you want measured.
