Disc trade, anyone?
- SpokeWheel650B
Disc trade, anyone?
03 Dec 2006 23:36
OK, in gathering my bits to change over to dual disc on my '78 KZ650B2 I bought an NOS front rotor on Ebay for waaayyy too much $. Thinking it would be a match to my orig rotor, I was surprised to see it is exactly the same in every way EXCEPT it's a couple mm's thinner! :ohmy:
I need a 7mm thick rotor in good, smooth shape...I will trade someone even-up for the correct disc! Email or PM me asap please.
many thanks all,
Ray Kelley
many thanks all,
Ray Kelley
- steell
Re: Disc trade, anyone?
04 Dec 2006 07:56
The rotors on the dual disk models are thinner than the rotors on the single disk models, so I suggest finding another thin one to match the one you already have.
- Samwell
04 Dec 2006 08:12
I've got one that may fit the bill. I'll measure it up and send you a few pics if you like.
Sam
SpokeWheel650B wrote:
Sam
many thanks all,
Ray Kelley
- SpokeWheel650B
04 Dec 2006 08:38The rotors on the dual disk models are thinner than the rotors on the single disk models, so I suggest finding another thin one to match the one you already have.
Thanks Steell, I was wondering about the reasoning behind the thinner disc, got it;) Will a std thick disc NOT work in this app? Just wondering if I am gonna run into trouble or not.
Thanks Sam, please send the pics you have and if you would meassure the thickness I would appreciate it
regards, Ray
Post edited by: SpokeWheel650B, at: 2006/12/04 11:41
- steell
04 Dec 2006 08:49
The standard thick single disks will work, they just increase the unsprung weight.
I have used two of the thick disks on one of my twins until I could get a pair of thinner ones.
- 77KZ650
04 Dec 2006 09:08
like steell said, they will work, they are just heavier. you should be able to run one of each no trouble too, the piston in the caliper should move in more with the thin one when you bleed the brakes so they should grab equally
if you want a thick one instead, I have one, they are 7mm thick (I have the whole front end minus the steering stem I could get rid of actually)
Scott
Scott
07 MDP Rookie of the Year
- SpokeWheel650B
04 Dec 2006 14:29
Hi Scott, I think I ultimately would like them to match; thick or thin no matter really
Let me know how you want to work the trade, your disc is in good smooth shape, mine is very clean and would like a near match if possible.
thanks much!
Ray
thanks much!
Ray
- 77KZ650
04 Dec 2006 15:05
Wireman and I were going to swap awhile back, but I have upgraded the whole front end instead. I dont really want to trade, but Ill let it go for a fair price since its no good to me. Wireman has first dibs if he still wants it though...
Scott
Scott
- 77KZ650
04 Dec 2006 15:10
- 77KZ650
04 Dec 2006 15:11
- fixer5000
04 Dec 2006 15:17
steell wrote:
i have two thicker ones on mine. i dont really notice the weight gain at all. sure does stop a heck of alot better though...steve
1978 kz650b pretty much stock
massachusetts
massachusetts
- wireman
04 Dec 2006 15:30
ive got plenty of front rotors but i would give my left tganek:whistle:
for a couple good rear undrilled kz1000 style rotors!
