77 kz650 rear wheel & mufflers
- 1stkz650
02 Dec 2006 11:33
i need to replace my rear drum brakes. but the mufflers are in the way. can i remove the mufflers with out having to take the entire exhaust system apart? pleae help thanks
- RetroRiceRocketRider
Re: 77 kz650 rear wheel & mufflers
02 Dec 2006 11:56
Yes.
Just about where the exhaust goes under the front footpegs are you will see a little chrome "beauty shield" held on by a screw, behind that there is a clamp that holds the rear muffler section to the header pipe. Loosen the bolt on that clamp, remove the bolt in the rear that holds the muffler to the rear footpeg, and just twist the muffler back-and-forth as you pull it backwards and it should slide right off.
I would suggest replacing the gasket at that clamp point when you re-install it so you don't end up with a noisy exhaust leak.
Covina, So Calif!
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
89 GSX1100F Katana = SLEEPING
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
- 1stkz650
02 Dec 2006 12:40
Glad to be of help.
Covina, So Calif!
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
- rstnick
02 Dec 2006 16:36
You can remove the rear wheel straight out towards the back without needing to remove your mufflers.
Disconnect the torgue link (#
from the drum.
Loosen the rear axle nut, allowing the wheel to move forward.
Remove bolts #16 and parts #18 (Stoppers) from the swingarm.
Disconnect the drive chain and slide the wheel off to the back.
Post edited by: rstnick, at: 2006/12/02 19:38
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- Bluemeanie
03 Dec 2006 20:07
As rstnick says, you HAVE to remove the rear wheel as the axle passes thru the drum brake backing plate, remove wheel, remove backing plate (right side)and the brakes are in your hand!
- Bluemeanie
03 Dec 2006 20:10
