Should I have an engine sprocket guard?
- Samwell
12 Oct 2005 03:42
In my on going rebuild I'm replacing my clutch cable and much to my dismay I find I'm missing this sprocket guard. At least my clymer manual says I should have one. There are unused holes to bolt it on, but guard per se. I dug around on Kawi's website but can't locate it to get a part number.
This guard is a flat metal plate that covers the front engine sprocket and is nestled under the front sprocket cover.
Any ideas?
Sam
Any ideas?
Sam
- steell
Re: Should I have an engine sprocket guard?
12 Oct 2005 04:25
IMHO, it don't weigh much, don't usually get in the way of anything (unless you need the room for an oversized sprocket) and it may help limit the damage if you break a chain, so why not put one on.
If you list the year/model in question, maybe someone has an extra they would be willing to get rid of.
- Samwell
12 Oct 2005 15:25
Sorry, I should have listed the model. I think I've updated my sig file to include it.
Anyway, it for a '78 KZ1000A2. I'm all for having one, its just I don't know where to find one, and I can't seem to locate it on Kawi's website to find a part number for it.
thanks for your help...Sam
- dannyg40
12 Oct 2005 17:04
Good question !
Im wondering if anyone knows if them chain guards are all exactly the same, or is some are different. My 750 - 4 has a 13 tooth front sprocket, and if I get a 14 tooth for the front, it would be extremely close to the front chain guard. I see the specs of some different models of KZ's that use a 15 or even 16 tooth front sproket on the same 750 engine. Is there a different front chain guard that allows the extra room ?
- savedrider
- 1975 Z1-B 900
12 Oct 2005 17:13
It's not just you Samwell...I just checked the fiche on
www.partsfish.com
and sure enough I cannot locate that cover you are talking about. Maybe they did not use it on your year bike even though the bolt holes are still there?
I don't think you absolutely have to have it anyhow. It might sling a little more grunge around in there and if the chain did break that would suck. I wouldn't worry about it.
Get right or get left! <*{{{><
- wireguy
18 Nov 2005 19:44
i dont remember ever seeing a sprocket gaurd,the on thing i can think of is the perforated piece that mounts inside the cover,is this what youre talking about?
- rstnick
18 Nov 2005 20:04
Is part # 21 not a sprocket cover? The discription is not but it sure looks like one: Part # 21 14025-1106 COVER,TRANSMISSION
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- wireguy
18 Nov 2005 22:00
13-14 are the pieces i was thinking about,is it one of these?
- steell
19 Nov 2005 05:52
13 and 14 are covers, 21 is the trans cover while 22 is the gasket. The chain/sprocket guard bolts to #21 and is a flat piece of metal perpendicular to it. It forms a curve in front of the chain to prevent the chain from eating the crankcase when it breaks.
- kawtoy
19 Nov 2005 08:19
I am pretty sure if you were missing #21 you would aslo be missing lots of oil. It has a shaft seal that slides over the sprocket shaft. Without this seal lots of oil would be pouring out.
Harley Davidson- Turning gas into noise without the harmful affects of horsepower for over 100 years.
- 79MKII
- Love Them Kaws!
19 Nov 2005 10:44
Yea, #21 mounts to the engine to seal the trans and is INSIDE the sprocket. The only "cover" I have seen is #13 and #14 which is insulation to deaden sound and maybe add a little strength. Generally the entire large cover is considered the sprocket cover. You have to have some kind of sprocker cover to mount the clutch cable to the clutch actuator/pushrod. Another cool option is this cover:
www.pmfronline.com/clutch_release_kits.htm
I just realized that you are using a Clymer...they are for many different models/years. The early 900's had a cover like you are talking about. This diagram is from a '73 Z1. See part number 15. I don't think the later years had them.
15 14024-008 COVER,ENGINE SPROCKET
Post edited by: 79MKII, at: 2005/11/19 13:49
The Kaw List:
- 79MKII
- Love Them Kaws!
19 Nov 2005 10:51
The Kaw List:
